dskar
#1 Posted : Sunday, June 10, 2012 5:16:27 AM(UTC)
dskar
When I turn on the oven the timer doesn't start but the oven does heat up a little but not to temp. I know the elements are working because they will glow red for a minute. Can someone tell me what might be wrong?
#2 Posted : Tuesday, June 12, 2012 2:51:25 AM(UTC)
Replacement parts for Whirlpool GR450LXHB2 30" ELECTRIC RANGE CERAN COOKTOP Convection Oven | AppliancePartsPros.com
Does the oven come ready or does it stay in preheat?
If it comes ready then it could be that it is not getting the correct oven temperature so check the oven sensor.
Here is info on it, look at 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
Also check that the connection to the sensor arew clean and secure.
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Lower Oven doesn't heat properly (Oven Repair (including Ranges and Cooktops))
by Softballfan 4/16/2016 1:45:41 PM(UTC)
fridgidaire oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by debshroom 5/8/2013 7:15:43 AM(UTC)
upper oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by stephen36 2/25/2013 11:57:09 AM(UTC)
Oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by bobby6432 10/26/2012 3:28:27 PM(UTC)
Whirlpool SB130PER4 Gas Wall oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by sikhnerd 10/17/2012 10:00:32 AM(UTC)
by Silvernick 5/15/2012 8:20:59 PM(UTC)
oven doesn't heat to selected temp. (Oven Repair (including Ranges and Cooktops))
by jimsmithbc 10/31/2011 1:54:50 PM(UTC)
Magic Chef gas oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by jand 7/1/2011 9:23:12 AM(UTC)
Oven doesn't heat after bright flash (Oven Repair (including Ranges and Cooktops))
by markmelancon 6/17/2011 11:10:57 AM(UTC)
Electric Range oven doesn't heat - stove top works (Oven Repair (including Ranges and Cooktops))
by deannastevens70 3/2/2011 8:54:15 PM(UTC)
GE Oven doesn't heat after using self clean (Oven Repair (including Ranges and Cooktops))
by Elmo1 2/3/2011 4:57:50 PM(UTC)
GE oven doesn't heat up everytime (Oven Repair (including Ranges and Cooktops))
by IntermittentGE-Oven 12/20/2010 3:49:12 PM(UTC)
Magic Chef oven doesn't heat (Refrigerator & Freezer Repair)
by Francisco Dan 12/7/2010 12:46:57 PM(UTC)
Oven doesn't heat to temperature (Oven Repair (including Ranges and Cooktops))
by msdahl 11/5/2010 11:41:01 AM(UTC)
