jimsmithbc
#1 Posted : Monday, October 31, 2011 1:54:50 PM(UTC)
jimsmithbc
Main oven does not heat to selected temp.Ruled out bake element.
No code. Broiler element works, bake element does not.
Please help.
Thanks,
Jim Smith
herbstuff@centurylink.net
205-487-9028 cell
#2 Posted : Wednesday, November 2, 2011 2:05:04 AM(UTC)
Replacement parts for KENMORE 79099513307 by Kenmore Elite | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...assomption/318045334.pdf
I am assuming that everything looks normal when you go into bake, re: the unit does go into bake and shows the actual oven temperature but it never reaches the set point temperature.
Also I am assuming that the convection element works.
Odds are that the control/timer board is shot.
Part number: AP4057261
Another possibility would be that the oven sensor is shot but I would expect the bake cycle would show that it is at set point temperature.
You may want to check it.
Here is a good link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
