deannastevens70
#1 Posted : Wednesday, March 2, 2011 8:54:15 PM(UTC)
deannastevens70
Electric Range oven doesn't heat or broil - stove top works. What could this be? Thanks
#2 Posted : Thursday, March 3, 2011 2:46:52 AM(UTC)
Your model number is missing several digits at the end so I cannot find any info on it.
I can tell you that is actually a Frigidaire.
Some units have a thermal cut-out for the oven elements.
deannastevens70
#3 Posted : Thursday, March 3, 2011 6:23:46 PM(UTC)
deannastevens70
Model 790.9503.9700
#4 Posted : Friday, March 4, 2011 12:48:29 AM(UTC)
Replacement parts for KENMORE 79095039700 | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441458en.pdf
At the top of the list is a wire that has burned off or the control board.
Check the wiring from the terminal strip to the control board and from the control board to the elements.
I would also check the ovens temperature sensor but this is a long shot.
Here is a good link, see items 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
If the wiring and the sensor are OK then odds are very high that the control board needs replacing.
deannastevens70
#5 Posted : Friday, March 4, 2011 9:06:50 AM(UTC)
deannastevens70
I will let you know how it goes.
