FoByFo
#1 Posted : 13 years ago
FoByFo
It will take the oven about 30 minutes to heat up to 350. The oven flame doesn't look robust - It looks small. Also, the gas is making a sputtering sound through the oven burner when the oven heat is on. I replaced the dual safety valve. It seemed to help some but not much. It is still sputtering and the flame still looks small. I have checked the lines from the manifold to the burner and they are all clear. What's next?
Thanks.
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
You should check the oven ignitor' s amperage draw. The normal is 3.25amp.If it is less - replace the ignitor. See if you can adjust the burner's orifice.
The ignitor bake Part number: 415504
Part number: 415504
Here are the breakdown diagrams and Replacement parts for Thermador PRG364GDUS GAS RANGE | AppliancePartsPros.com
PS. Is the broil works OK?
Thank you. Post the results.
Simon.
FoByFo
#3 Posted : 13 years ago
FoByFo
Thank you for the reply. That was exactly the problem. I felt a bit stupid. I posted that query late the evening after fighting that and another unrelated problem all day and I was too tired to think. I did a search the next morning and found the answer you ended up providing here. That was too easy - but not cheap. A clear example of the adage about experience being based on good judgement that is the result of learning from bad judgement.
Thanks again. Have a good day.
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
You are welcome. Thank you for sharing with us.
Simon.
Electric Oven Slow to Heat Up (Oven Repair (including Ranges and Cooktops))
by deere420 8 years ago
Oven SLOW to heat (Oven Repair (including Ranges and Cooktops))
by Sfs_cds07@yahoo.com 8 years ago
oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ndobois@yahoo.com 11 years ago
GE XL44 Gas Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Vinnyboy6527 12 years ago
Samsung Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by lymansbay 14 years ago
gas oven slow to heat up/achieve desired temperature (Oven Repair (including Ranges and Cooktops))
by FPF 14 years ago
GE XL44 Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by solo12357 14 years ago
Electric oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Fairbob 16 years ago
Oven slow to heat up but broiler works (Oven Repair (including Ranges and Cooktops))
by drcain 17 years ago
Oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ladbroke 17 years ago
