4 Pages<1234>
chilidog
#21 Posted : Tuesday, May 22, 2012 4:39:18 AM(UTC)
chilidog
chilidog
#22 Posted : Tuesday, May 22, 2012 11:23:40 AM(UTC)
chilidog
Gene, I put in a new thermosat, 9757807, and the spark control, w10331686. Oven doing the exact same thing. Panel shows temp at 325*, beeped after warm up, is 186* inside. Fan running, heat indicater on panel not illuminated. Also, I have installed the new control board.
#23 Posted : Tuesday, May 22, 2012 2:26:56 PM(UTC)
The problem you described has nothing to do with this thermostat.
Retest the oven sensor. It should be tested at the room temperature.
How did you measure the oven temperature? Describe it step by step please.
Install the new control board (which you purchased from Whirlpool) and give it a try with the new spark module installed as well.
chilidog
#24 Posted : Tuesday, May 22, 2012 3:39:47 PM(UTC)
chilidog
The oven sensor is at 1108 ohms. I just reinstalled the new control board, and the new spark control board. With the temp set at 350*, it has restarted or tried to at least 5 times before it has competed the pre-heat session.
I am using a digital thermostat with a silicone wire, metal probe and a laser digital thermometer used in home a/c, heating monitoring. After pre heat session is complete, oven is still restarting, panel shows 350*, both thermometer showing about 190*, and dropping.
15:00 later. After pre heat, oven fan still going, shows 350* on panel, heat and bake light still lit on panel. Digital thermostat reading is now at 159*.
#25 Posted : Tuesday, May 22, 2012 3:45:30 PM(UTC)
Originally Posted by: chilidog Go to Quoted Post
...The oven sensor is at 1108 ohms...
At what temperature did you get it?
chilidog
#26 Posted : Tuesday, May 22, 2012 3:53:30 PM(UTC)
chilidog
The sensor temp was room temp, about 70*.
After 30 minutes, I turned oven off. It showing 350* still, fan running, thermometer reading 120* and dropping.
#27 Posted : Tuesday, May 22, 2012 4:29:33 PM(UTC)
The normal reading at 70°F suppose to be 1080 Ohm. 1108 Ohm reading corresponds to 83°F.
Where did you measure it: at the control board or at the sensor plug on the back of the range? More accurate way in such situation is to do it at the control board plug.
Also, a laser thermometer is not accurate to use it in ovens. It measures a temperatures of a metal surfaces but not the air temperature inside the oven. You have to have the oven on for at least two hours to get such reading more or less accurate. I'm afraid I did not get clear what did you mean
Quote:
...a digital thermostat with a silicone wire, metal probe...
Did you open the oven door during the oven temperature tests?
Quote:
... After pre heat session is complete, oven is still restarting...
Also I did recommend you to order the burner/igniter assembly if the flame will cycle on & off.
Don't worry about money you paid for parts because you always can return unneeded parts later.
P.S. I hope you understand that I'm trying to diagnose the problem with your oven remotely and, doing that, I should rely on all information provided by you.
chilidog
#28 Posted : Tuesday, May 22, 2012 4:44:44 PM(UTC)
chilidog
The thermometer is on a wire probe, the door is staying closed on the cord. I live at 8700 feet, I wonder if enlarging the holes on the burner made it worse. For other gas, gasoline products, we put smaller jets(orifice) in them because of thin air to adjust the fuel input. Wouldn't drilling out the burner as I did increase the fuel and lower the oxygen?
I took the oven back off again to check the temp probe. I wasn't aware of the wire color to check it from the front. I have ordered the burner assy, some how I messed up the order, only ordered the spark control.
Thanks for any help, Ron
chilidog
#29 Posted : Tuesday, May 22, 2012 4:58:20 PM(UTC)
chilidog
Gene, I just ran the clean cycle for a few minutes, It got up over 500*, I could see the burner through the glass, it never went out or tried to relight. It was on constant. My temp probe only goes to 500*, so I know it much much warmer. Everything seemed to work as normal, door locked, I could time self clean, all panel lights came on as they should. Does this tell you anything?
#30 Posted : Tuesday, May 22, 2012 4:58:29 PM(UTC)
...I live at 8700 feet, I wonder if enlarging the holes on the burner made it worse...
Yes Ron. At such elevation it definitely made it worse. Very likely the igniter, which is the flame sensor at the same time, does not do it well because of weak flame. Order and instal the new burner.
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Oven shuts off by itslf (Oven Repair (including Ranges and Cooktops))
by kdsagun 4/15/2018 5:55:28 PM(UTC)
Oven shuts off after heating up (Oven Repair (including Ranges and Cooktops))
by ravellar 4/24/2017 12:10:21 PM(UTC)
Whirlpool oven shuts off baking/broiling (Oven Repair (including Ranges and Cooktops))
by bremen242 2/13/2017 4:12:13 PM(UTC)
Whirlpool Gold oven shuts off when temp changed (Oven Repair (including Ranges and Cooktops))
by texicus 9/24/2015 9:30:38 AM(UTC)
Panasonic oven shuts off NN-SA651S (Microwave Repair)
by ladybridgeport 4/23/2014 10:49:07 AM(UTC)
Oven shuts off by itself (Oven Repair (including Ranges and Cooktops))
by bobtam 5/16/2013 3:40:22 PM(UTC)
oven shuts off after 45 min (Oven Repair (including Ranges and Cooktops))
by Karl Lauther 4/22/2013 2:49:55 PM(UTC)
kenmore ultra bake oven shuts off (Oven Repair (including Ranges and Cooktops))
by urbanrover 3/13/2013 12:47:40 PM(UTC)
Oven shuts off while cooking, sometimes trouble starting (Oven Repair (including Ranges and Cooktops))
by mrs9693nj 2/15/2013 1:31:41 PM(UTC)
JENN-AIR oven shuts off after a few minutes of heating (Oven Repair (including Ranges and Cooktops))
by toolrules 2/10/2013 7:45:46 PM(UTC)
After pre heat oven shuts off (Oven Repair (including Ranges and Cooktops))
by rider136 9/24/2012 3:37:31 PM(UTC)
Jenn-air oven shuts off (Oven Repair (including Ranges and Cooktops))
by Wardenmotorsports 9/18/2012 4:21:59 PM(UTC)
Oven shuts off (Oven Repair (including Ranges and Cooktops))
by richwest41 8/22/2012 4:10:05 PM(UTC)
Oven shuts off within ten minutes (Oven Repair (including Ranges and Cooktops))
by TMeck 8/22/2012 2:00:23 PM(UTC)
4 Pages<1234>
