Erika555
#1 Posted : Tuesday, May 22, 2012 9:40:36 AM(UTC)
Erika555
The flame on my stacked gas dryer goes out after it is lit by the igniter. It sounds like I need to replace the gas valve coils.
How do I access them? I removed the front panel and they seem closer to the back. Is there a back panel I should access them through?
Thanks!
Simon / APP Team
#2 Posted : Tuesday, May 22, 2012 1:29:27 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the flame cycling on and off?
For how long it's stays on?
When there is no flame do you see the ignitor glow?
Thank you. Post the results.
Simon.
Erika555
#3 Posted : Tuesday, May 22, 2012 3:01:10 PM(UTC)
Erika555
The flame stays on for 5-10 seconds.
The igniter is not on when the flame is out.
The igniter stays off for awhile and when it comes back on the flame engages for a few seconds before all goes dark again.
Simon / APP Team
#4 Posted : Tuesday, May 22, 2012 7:27:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The problem with your dryer is clogged exhaust vent.
Remove the vent hose from the dryer and run it for one cycle.
If it works fine - clean the vent, if not - clean the dryer internal vent system.
Simon.
Erika555
#5 Posted : Wednesday, May 23, 2012 6:44:49 PM(UTC)
Erika555
Wow! I disconnected the vent from the dryer and the flame stayed on for several minutes, when I reconnected the vent, the flame went out.
I had no idea. Time for a visit from the vent cleaning service.
Thank you!!!
Simon / APP Team
#6 Posted : Thursday, May 24, 2012 10:37:01 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
