4 Pages123>»
chilidog
#1 Posted : Sunday, May 13, 2012 5:45:59 PM(UTC)
chilidog
After oven lights, it heats for a few minutes, then gas goes off. Oven thinks it still on , but doesnt get warm. Have changed control panel, no help.:mad:
#2 Posted : Monday, May 14, 2012 5:13:00 PM(UTC)
Would it click again to reignite the oven?
Here are the breakdown diagrams and Replacement parts for Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV | AppliancePartsPros.com
chilidog
#3 Posted : Tuesday, May 15, 2012 6:22:35 AM(UTC)
chilidog
Yes, I turn off at control panel, turn back on, does the same thing most of the time. It will go to intended heat about every sixth time. When it tries to reclick, sometimes it lights, sometimes not. Mostly I found out it not staying lit after it had been cooking with timer at 350*. It was only about 200*, after 30 minutes. I cleaned the igniter, bent it closer.
#4 Posted : Tuesday, May 15, 2012 5:10:55 PM(UTC)
You have to check the Bake burner lighting holes. You can find more information in one of our previous threads: http://forum.appliancepartspros...e-will-not-stay-lit.html
- The Bake burner assembly Part number: 8191123
chilidog
#5 Posted : Wednesday, May 16, 2012 6:41:58 AM(UTC)
chilidog
I took out bake burner, drilled the 8 holes one size bigger. Oven lights, runs a few minutes, then you can hear gas valve shut off. After a minute or two, gas valve opens, tries to ignite, no flame, then gas valve shuts off again.Right now oven panel says it is at 350*, digital thermometer only showing 201*, panel says in heat mode, fan still running. Has been running for ten minutes now, shows 350* still, is 189* inside. Has not tried to reignite for more than 5 minutes.
After 15 more minutes, Oven still thinks it is on, showing 350*, fan going, is 141* inside now.
chilidog
#6 Posted : Wednesday, May 16, 2012 7:04:18 AM(UTC)
chilidog
I also tested oven sensor with digital ohmeter. It shows just over 1100 ohms, close to 1200 after oven had been warm. Gas valve reading at 222 on upper connectors, 218 on lower.
#7 Posted : Wednesday, May 16, 2012 1:13:58 PM(UTC)
Originally Posted by: chilidog Go to Quoted Post
...Have changed control panel, no help...
Which part exactly did you replace? What is the part number?
chilidog
#8 Posted : Wednesday, May 16, 2012 2:13:04 PM(UTC)
chilidog
I replaced the control panel. I had a new one I got from Whirlpool, oven shut down last year due to self clean. They said was control panel , was thermal fuse.. Control panel part number is 9760013.
Thanks for your help
#9 Posted : Wednesday, May 16, 2012 2:45:54 PM(UTC)
This part actually is the control board.
Do you have the same problem with the Broil?
chilidog
#10 Posted : Wednesday, May 16, 2012 3:00:25 PM(UTC)
chilidog
Yes, I bought the control panel from Whirlpools advice. The oven had gone dead after self clean. When that didn't fix it, I found out the thermal fuse had blown. Couldn't return panel.
I put the original control panel back in, about the same time this oven problem began, the light bulbs stopped coming on when door is open. I don't know if any relation to oven not staying lit.
Yes , the broiler lit right up, stayed on till I turned it off.
Guest (10)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Oven shuts off by itslf (Oven Repair (including Ranges and Cooktops))
by kdsagun 4/15/2018 5:55:28 PM(UTC)
Oven shuts off after heating up (Oven Repair (including Ranges and Cooktops))
by ravellar 4/24/2017 12:10:21 PM(UTC)
Whirlpool oven shuts off baking/broiling (Oven Repair (including Ranges and Cooktops))
by bremen242 2/13/2017 4:12:13 PM(UTC)
Whirlpool Gold oven shuts off when temp changed (Oven Repair (including Ranges and Cooktops))
by texicus 9/24/2015 9:30:38 AM(UTC)
Panasonic oven shuts off NN-SA651S (Microwave Repair)
by ladybridgeport 4/23/2014 10:49:07 AM(UTC)
Oven shuts off by itself (Oven Repair (including Ranges and Cooktops))
by bobtam 5/16/2013 3:40:22 PM(UTC)
oven shuts off after 45 min (Oven Repair (including Ranges and Cooktops))
by Karl Lauther 4/22/2013 2:49:55 PM(UTC)
kenmore ultra bake oven shuts off (Oven Repair (including Ranges and Cooktops))
by urbanrover 3/13/2013 12:47:40 PM(UTC)
Oven shuts off while cooking, sometimes trouble starting (Oven Repair (including Ranges and Cooktops))
by mrs9693nj 2/15/2013 1:31:41 PM(UTC)
JENN-AIR oven shuts off after a few minutes of heating (Oven Repair (including Ranges and Cooktops))
by toolrules 2/10/2013 7:45:46 PM(UTC)
After pre heat oven shuts off (Oven Repair (including Ranges and Cooktops))
by rider136 9/24/2012 3:37:31 PM(UTC)
Jenn-air oven shuts off (Oven Repair (including Ranges and Cooktops))
by Wardenmotorsports 9/18/2012 4:21:59 PM(UTC)
Oven shuts off (Oven Repair (including Ranges and Cooktops))
by richwest41 8/22/2012 4:10:05 PM(UTC)
Oven shuts off within ten minutes (Oven Repair (including Ranges and Cooktops))
by TMeck 8/22/2012 2:00:23 PM(UTC)
4 Pages123>»
