FloridaRay
#1 Posted : Thursday, April 26, 2012 5:47:03 PM(UTC)
FloridaRay
Warm fridge while lower freezer drawer cold and making ice. Fridge temp control
works - opens and closes but no airflow. No frost on any coils or water in drip pans. Condenser fan works. Thanks for any help. Ray
FloridaRay
#2 Posted : Thursday, April 26, 2012 8:57:16 PM(UTC)
FloridaRay
Update. Back of freezer frozen. Back of inside of freezer that is. Defrosted and now have cold going to fridge. At least for now.
#3 Posted : Friday, April 27, 2012 1:29:09 AM(UTC)
Replacement parts for MBF2556KEQ1 models | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If yes.
Manually force a defrost cycle,see the tech sheet. When the fans and compressor turn off you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the control board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, 30 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
FloridaRay
#4 Posted : Tuesday, July 9, 2013 12:22:40 PM(UTC)
FloridaRay
Had fridge checked out by service company. Tested good for defrost parts. Has been working last seven months. Now freezing up again. Got a new control board per repairmans advice, but can't remove cover plate (housing). I don't want to break it. Thanks. Ray
#5 Posted : Thursday, July 11, 2013 2:33:23 AM(UTC)
See the attachment for the tech sheet a KEQ1 does not come up but a KEQ11 does.
Here is a service manual. You will have to join the site, then login to ba able to download the manual.
http://appliancejunk.com...wnloads;sa=view;down=409
I am not sure when the board replacement was recommende. If it was 7 months ago then it may not be the correct diagnosisi for today.
I would force a defrost cycle.
If the heater comes on then I would replace the board.
If it does not come on then I would check the heater and the defrost thermostat with a meter to see if they are OK.
If they measure OK then I would replace the board.
Note that if the defrost thermostat is deformed/bulged I would replace it even if it measures OK.
File Attachment(s):
MBF2556.pdf (468kb) downloaded 5 time(s).
Freezer warm fridge section is fine (Frigidaire Professional FPHB2899LF6) (Refrigerator & Freezer Repair)
by bc1016 6/24/2021 8:54:35 PM(UTC)
Whirlpool WRT311FZDW00: Ice buildup in freezer, warm fridge (Refrigerator & Freezer Repair)
by bkbk 9/16/2019 3:42:31 PM(UTC)
Freezer coils/condenser still freezing-over causing warm fridge.Thermostat changed (Refrigerator & Freezer Repair)
by fridge123fr 9/2/2019 9:33:23 PM(UTC)
freezer not freezing /warm fridge.. help! (Refrigerator & Freezer Repair)
by Chickadee 10/8/2016 8:06:02 AM(UTC)
Heater in warm fridge glowed, but now won't (Refrigerator & Freezer Repair)
by ithryn 7/20/2016 6:27:25 PM(UTC)
Condenser fan never runs, related to warm fridge? (Refrigerator & Freezer Repair)
by valsidalv 11/10/2015 7:10:05 PM(UTC)
Maytag Cold freezer/Warm Fridge (Refrigerator & Freezer Repair)
by chris hesselgrave 11/14/2014 7:15:16 AM(UTC)
by JamesO 8/14/2014 1:32:55 PM(UTC)
by Matt_in_FW 7/23/2014 12:43:45 PM(UTC)
Clicking sound & warm fridge (Refrigerator & Freezer Repair)
by gtg932 4/26/2014 4:08:34 PM(UTC)
Warm Fridge (Washer Repair)
by JamesO 4/8/2014 12:35:15 PM(UTC)
warm fridge, cool freezer (Refrigerator & Freezer Repair)
by stavros 3/11/2014 8:01:04 PM(UTC)
warm fridge/cold freezer (Refrigerator & Freezer Repair)
by sillyfilly72 8/18/2013 2:54:51 PM(UTC)
warm fridge and no ice (Refrigerator & Freezer Repair)
by aglazner 8/18/2013 7:06:42 AM(UTC)
Whirlpool Gold Conquest: warm fridge (Refrigerator & Freezer Repair)
by dawydiuk 8/17/2013 9:45:44 AM(UTC)
