My Frigidaire built-in microwave suddenly stopped working. The timer begins to count down, and the light lights, but nothing else is working. Ideas??
Groups: APP Team
Hi. Most likely the problem is with monitor switches (switch). Unplug the oven, remove control panel and on the left side locate 3 switches. The primary and secondary monitor switches has two wires each. You may have bad switch or burned connector. In any cases replace both. Run the continuity test. With one wire off: Door closed - continuity, door open - no continuity. Replace bad switch. The interlock switch Part number: AP3769802
OK. I tested both switches. Got continuity in both of them. Now what?
Groups: APP Team
Hi.
Did you removed the switches for testing? You suppose to check them in the place and actually open and close the door. What tab is broken?
Please reply.
Simon.
