Tightline
#1 Posted : 13 years ago
Tightline
My Frigidaire built-in microwave suddenly stopped working. The timer begins to count down, and the light lights, but nothing else is working. Ideas??
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is with monitor switches (switch).
Unplug the oven, remove control panel and on the left side locate 3 switches.
The primary and secondary monitor switches has two wires each. You may have bad switch or burned connector. In any cases replace both.
Run the continuity test. With one wire off:
Door closed - continuity, door open - no continuity.
Replace bad switch.
The interlock switch Part number: AP3769802
Here are the breakdown diagrams and Replacement parts for Frigidaire FMV156DCC Frigidaire/microwave | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Tightline
#3 Posted : 13 years ago
Tightline
OK. I tested both switches. Got continuity in both of them. Now what?
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Did you removed the switches for testing? You suppose to check them in the place and actually open and close the door.
What tab is broken?
Please reply.
Simon.
Whirlpool Microwave stopped working (Microwave Repair)
by Myron S 7 years ago
Over the oven microwave stopped working (Microwave Repair)
by Paul Buckley 12 years ago
GE Microwave stopped working (Microwave Repair)
by Scottg5050 12 years ago
Frigidaire Microwave stopped working (Microwave Repair)
by Grace11797 13 years ago
GE Microwave stopped working. No lights nothing (Microwave Repair)
by Johndgay 13 years ago
GE Microwave stopped working,everything (Microwave Repair)
by Beatlesrit 15 years ago
Old Hotpoint Microwave Stopped Working (Microwave Repair)
by Pat Smith 15 years ago
Whirlpool combination hood light microwave stopped working (Microwave Repair)
by wpej55 16 years ago
Please Help....Microwave stopped working (Microwave Repair)
by unc25 16 years ago
Whirlpool Microwave Stopped Working (Microwave Repair)
by sandsbz 16 years ago
by patsoven 17 years ago
