AlexP
#1 Posted : Monday, March 16, 2009 3:51:15 PM(UTC)
AlexP
My whirlpool dryer just stopped heating the other day. It still runs & blows air like normal but does not heat up. I'm guessing it's either a fuse or the heating element but I don't want to order a part w/o knowing for sure what the problem is.
Any recommendations on how to diagnosis it? Thanks.
Alex
#2 Posted : Monday, March 16, 2009 5:52:52 PM(UTC)
Here is your parts
Replacement parts for WHIRLPOOL LER4634JQ1 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
First turn the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure for 220 volts at the plug
Next would be the heater or the thermal fuse (Item 6 Section 3).
Best to check with a meter.
You can check the fuse by unplugging the unit, shorting the wires to the fuse together, tape them up so they cannot short to the frame, pluge the unit in and give it a try.
If the fuse is blown be sure to clean/check the vent system, the blower wheel, the lint filter screen and the drum seals.
Some times the lint filter can get coated with fabric softener and must be cleaned with soap and water.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Whirlpool Dryer Not Heating (Dryer Repair)
by Frustrated42 11/8/2015 7:21:05 AM(UTC)
by handygirl67 3/12/2015 1:14:03 PM(UTC)
whirlpool dryer not heating nor timer advancing (Dryer Repair)
by bladrnr 12/26/2013 12:39:41 PM(UTC)
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Whirlpool Dryer not heating (Dryer Repair)
by cindystarr 9/28/2012 2:57:39 PM(UTC)
Whirlpool dryer not heating or turning (Dryer Repair)
by splumer 9/22/2012 10:05:44 AM(UTC)
by ValpoMan 9/17/2012 3:34:11 PM(UTC)
by rdmousaw 8/7/2012 1:03:50 PM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
Whirlpool Dryer not heating well (Dryer Repair)
by rockettme 6/7/2012 9:22:08 AM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
by Phiphtie 1/4/2012 3:09:19 PM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
