marjfam
#1 Posted : Saturday, March 10, 2012 12:49:03 PM(UTC)
marjfam
I have a dryer (GE DWXR473ET3WW) which has started to squeal when in use...it comes and goes.
I think it may be the drum rear bearing but could anything else squeal like this such as the roller(s) or the drive unit?
JW Webster
#2 Posted : Monday, March 12, 2012 2:45:19 PM(UTC)
JW Webster
The drum rides on platic glides on the front and a drum bearing on the rear. Typically the dryer will squeal when the plastic bearing gets thin and starts making metal to metal contact between the metal drum and the mount. To replace the bearing you remove the drum and get the old bearing out (it is plastic and easily removed) then install the new bearing. Easy peasy. Repair photos:
GE Dryer repair Pix - SublimeMasterJW's Appliance Advice
Kenmore Elite Oasis Dryer Squealing (Dryer Repair)
by Secret Ingredient 2/24/2017 5:01:06 PM(UTC)
Dryer squealing, now won't start (Dryer Repair)
by NetExtra 12/2/2016 1:54:42 PM(UTC)
Dryer squeals like a stuck pig! (Dryer Repair)
by 0$fixall 8/3/2016 8:21:39 AM(UTC)
Black marks on clothing & dryer squeals at times (Dryer Repair)
by jesus freak 1/20/2015 11:12:29 AM(UTC)
Whirlpool dryer squeals loudly (Dryer Repair)
by Mister_tom 5/22/2013 8:13:49 PM(UTC)
by wallywattz 7/25/2012 6:30:45 PM(UTC)
Dryer squeals, drum feels loose (Dryer Repair)
by Tru2Chevy 2/26/2012 6:55:11 AM(UTC)
dryer squeals really bad! (Dryer Repair)
by larrymerrell 2/25/2012 1:11:40 PM(UTC)
Dryer squeals while rotating (Dryer Repair)
by Mike Kane 2/11/2012 2:22:59 PM(UTC)
Electric dryer squealing (Dryer Repair)
by kenbreedlove 1/15/2012 7:50:54 PM(UTC)
Dryer Squeal on GE (Dryer Repair)
by Larrybackman 11/30/2011 4:21:43 PM(UTC)
Dryer squealing (Dryer Repair)
by yme 11/5/2011 3:43:22 PM(UTC)
My dryer squeals and doesn't dry properly (Dryer Repair)
by Robzilla 10/24/2011 10:08:34 AM(UTC)
Dryer squealing and squeaking loudly (Dryer Repair)
by upmawmaw 4/3/2011 4:49:29 AM(UTC)
Maytag elec dryer squeal (Dryer Repair)
by xtexan 2/22/2011 7:21:09 AM(UTC)
