Just replaced the Drum Support Rollers, Tumbler Bearings & main Belt. What els could be squealing? [and no, I looked, there are no piglets stuck in the dryer].:confused:
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Belt tension pulley, bearing in the motor or the fan is loose? My best guess is the belt tension pulley.
