xtexan
#1 Posted : Tuesday, February 22, 2011 7:21:09 AM(UTC)
xtexan
This dryer emits a squeal that varies from continual to pulsating at about 2-3 times per second. Pronounced upon startup, and then decreases with time. There are two squeals - one higher pitched, one lower. Squeal is completely gone once dryer heats up (after about 5 min).
Jeff / APP Team
#2 Posted : Tuesday, February 22, 2011 12:16:20 PM(UTC)
Jeff / APP Team
Click the link below this post should help you out. Your dryer will use the same rollers, but a different idler pulley. The part number for the pulley is below the link. Hope this helps.:)
http://forum.appliancepartspros...tag-squeaking-dryer.html
Part number: AP4373393
