cgo
#1 Posted : Saturday, March 7, 2009 3:29:45 AM(UTC)
cgo
Ican,t use just one side of the dual burner. If i turn on the single both come on . Any thoughts? Thanks in advance
chris
TechnicianBrian
#2 Posted : Saturday, March 7, 2009 6:52:24 AM(UTC)
TechnicianBrian
Most likely the infinite switch has failed and now powers both elements. We would needs to know which burner is the problem and the last digits of the models number to get you going in the right direction.
cgo
#3 Posted : Saturday, March 7, 2009 7:51:57 AM(UTC)
cgo
Thanks for the quick reply Brian. It is the left front burner with two elements. The model number is yker c600 hw Kitchen aid
SKU#415/ykerc600hw023540
TechnicianBrian
#4 Posted : Saturday, March 7, 2009 8:51:38 AM(UTC)
TechnicianBrian
This is the dual burner infinite switch (AP3751872) for your model. The panel is held in place by some screws under the panel just above the door. Turn the power off first, and then replace the switch.
cgo
#5 Posted : Sunday, March 8, 2009 4:12:55 AM(UTC)
cgo
Thanks for taking the time to reply Brian. I,ll pick one up monday
Dual Burner Cap for Jenn Aire Model JGS8860BDP is no longer made (Oven Repair (including Ranges and Cooktops))
by SVCirnee 11/20/2022 11:38:40 AM(UTC)
Jennair JEC9530ADW - Dual burner/custom control not working (Oven Repair (including Ranges and Cooktops))
by Eric D 11/1/2021 12:22:30 PM(UTC)
Kitchenaid gas cooktop Dual burners popping & flame-outs (Oven Repair (including Ranges and Cooktops))
by Weaklink 8/7/2020 10:06:17 AM(UTC)
Electric LG range dual burner doesn't work (Oven Repair (including Ranges and Cooktops))
by vasiliy 8/2/2019 5:09:30 PM(UTC)
Jenn-air dual burner tick tock (Oven Repair (including Ranges and Cooktops))
by neilwrob 10/5/2017 7:43:48 PM(UTC)
Maytag Gemini Front Right Dual Burner stays on High (Oven Repair (including Ranges and Cooktops))
by leday 2/19/2017 6:04:53 AM(UTC)
Replacing grill with dual burners (Oven Repair (including Ranges and Cooktops))
by drbob101 12/9/2015 9:47:43 AM(UTC)
The front left dual burner seems to go full hot from any selected position (Oven Repair (including Ranges and Cooktops))
by donnajp 11/9/2015 7:18:05 PM(UTC)
Jenn-Air SCE7600W range dual burner not heating (Oven Repair (including Ranges and Cooktops))
Belarus usethis 10/5/2014 2:01:03 PM(UTC)
Right Dual Burner Will not come on (Oven Repair (including Ranges and Cooktops))
by philton66 9/20/2014 7:48:34 AM(UTC)
Kitchenaid LF dual burner infinte switch # 8203536 (Oven Repair (including Ranges and Cooktops))
by mbrogan 3/4/2013 8:59:48 PM(UTC)
Dual burner not turning on (Oven Repair (including Ranges and Cooktops))
by puneet 1/28/2013 8:48:13 AM(UTC)
Kenmore Dual Burner Indicator Light Always On (Oven Repair (including Ranges and Cooktops))
by strictor 11/14/2012 5:11:31 PM(UTC)
Cooktop Dual Burner issue (Oven Repair (including Ranges and Cooktops))
by dkat1100 10/22/2012 2:41:39 PM(UTC)
Stove top dual burner stays on for 20 seconds then turns off. Red light is always on (Oven Repair (including Ranges and Cooktops))
by OveMarkstrom 10/3/2012 2:28:25 PM(UTC)
