Eric D
#1 Posted : Monday, November 1, 2021 12:22:30 PM(UTC)
Eric D
United States
Hey all,
Did a quick search and didn't find much on this particular model in regards to troubleshooting.
I have a Jennair JEC9530ADW - The front right burner is a Dual element or "Custom Control" burner. Probably about a month ago it just stopped working.
First glance I figured the element was bad because when I turn the knob in either direction, the power indicator light comes on and the cooling fan.
Ordered a replacement element, swapped it out...still nothing. I hooked my multimeter up and I can see power going to the element(120v), and could see power on the switch. However, I had no good way of testing the relays.
I did manage to get the big burner to come on for a second...not sure how...but it came on. turned it on before it got too hot. Put it all together, reinstalled...turned the knob and again nothing.
Ordered a replacement infinite switch, swapped it out...again nothing. The power indicator light comes on, fan comes on, just no element. Hooked the multimeter up and I see power again (120v) at the burner when it is on.
All the other burners work fine.
Thoughts on what I can check next? I'm really at a loss after replacing the two main parts I thought it could be.
Edited by user Monday, November 1, 2021 12:52:21 PM(UTC)  | Reason: Not specified
Eric D
#2 Posted : Monday, November 8, 2021 6:48:24 PM(UTC)
Eric D
United States
Any folks know what i could troubleshoot/check next? Appreciate the help!
