Joined: 11/1/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: WI
Hey all, Did a quick search and didn't find much on this particular model in regards to troubleshooting. I have a Jennair JEC9530ADW - The front right burner is a Dual element or "Custom Control" burner. Probably about a month ago it just stopped working. First glance I figured the element was bad because when I turn the knob in either direction, the power indicator light comes on and the cooling fan. Ordered a replacement element, swapped it out...still nothing. I hooked my multimeter up and I can see power going to the element(120v), and could see power on the switch. However, I had no good way of testing the relays. I did manage to get the big burner to come on for a second...not sure how...but it came on. turned it on before it got too hot. Put it all together, reinstalled...turned the knob and again nothing. Ordered a replacement infinite switch, swapped it out...again nothing. The power indicator light comes on, fan comes on, just no element. Hooked the multimeter up and I see power again (120v) at the burner when it is on. All the other burners work fine. Thoughts on what I can check next? I'm really at a loss after replacing the two main parts I thought it could be. Edited by user Monday, November 1, 2021 12:52:21 PM(UTC)
| Reason: Not specified
Any folks know what i could troubleshoot/check next? Appreciate the help!
