roeb
#1 Posted : Tuesday, February 21, 2012 7:54:13 PM(UTC)
roeb
I have a speedqueen washer and when I start it washing, it continues to wash and agitate and never advances. I have to manually advance it through each cycle, from wash to rinse to spin. Is this the timer or can it be something else?
sidfink43
#2 Posted : Thursday, February 23, 2012 4:53:29 PM(UTC)
sidfink43
It is highly likely it is the timer (actually the timer motor). Go ahead and replace the timer and see if that fixes things.
thorning
#3 Posted : Monday, July 21, 2014 7:08:35 PM(UTC)
thorning
It is probably not going to help this person but I have found the dryer timer motor which is 110 volt AC is pretty much the same on all the dryers I have worked on over the last couple of years. This applies to the mechanical timer assemblies used on the Whirlpool products. I took the cover off one of these recently and they are a maze of small plastic gears on most but not all. Maytag also used an integrated switch and timer and it is more robust as compared to the separate motor and switch arrangement. Many of the timers use 3 or 4 cycle type of rotary layout. The timer on the simple machines operates the dryer heating element and also the timer motor and has on some models a few other functions. The timer contacts are rated to handle approximately 25 to 30 amps at 240 volts for a heating element rated at 5500 watts. The newer model dryers use electronic controls with no mechanical working parts. these however are also weak in some parts of the circuit board and there is very little repair possible. A typical mechanical timer costs about $100. I am going to experiment on using an old rotary shaft timer from a Maytag electric dryer in a SpeedQueen electric dryer since the SpeedQueen replacement part is over $170 and is prone to wearing out.
Auto-dry setting timer does not advance (Dryer Repair)
by herseywa 6/16/2020 11:35:45 AM(UTC)
Timer knob skirt of my Maytag dryer MDE3500AYW does not advance. (Dryer Repair)
by Panayiotis C. Papasavvas 7/23/2019 1:08:45 PM(UTC)
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 9/11/2015 4:59:42 PM(UTC)
Timer does not advance (Washer Repair)
by Ray F 8/10/2015 6:13:40 PM(UTC)
Dial does not advance in Optimum Dry Mode (Dryer Repair)
by jpf3505 4/20/2015 8:14:57 AM(UTC)
Kenmore Heavy Duty 70 Series Washer Does Not Advance Cycle (Washer Repair)
by bdcs64 3/5/2015 6:07:36 PM(UTC)
Whirlpool (Roper) electric dryer runs and heats. Timer does not advance in auto or ti (Dryer Repair)
by biomed172 10/10/2014 6:12:03 PM(UTC)
Timmer does not advance (Dryer Repair)
by ejastro2002 9/7/2014 11:31:15 AM(UTC)
No Heat, Timer Does Not Advance (Dryer Repair)
by MRGETITFIXED 8/27/2014 8:36:01 AM(UTC)
Dryer Works Well But Timer Dial Does Not Advance (Dryer Repair)
by whudsonemt 9/15/2013 2:22:45 PM(UTC)
washer tub full spins but water still in timer does not advance (Washer Repair)
by scooty1 3/10/2013 6:55:34 AM(UTC)
Amana Dryer Timer Does Not Advance in Auto Mode (Dryer Repair)
by splehigh 3/5/2013 6:15:29 PM(UTC)
Fills with water, but does not advance (Dishwasher Repair)
by j_deodato@yahoo.com 12/12/2012 12:50:21 PM(UTC)
Whirlpool Dryer - No heat, Timer Does Not Advance (Dryer Repair)
by katielove22 10/21/2012 12:26:02 PM(UTC)
NO Heat - Timer does not advance (Dryer Repair)
by JMWITT 3/18/2012 6:08:06 PM(UTC)
