AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer Works Well But Timer Dial Does Not Advance
i HAVE A ROPER DRYER WHICH WORKS WELL. THE TIMER JUST DOES NOT MOVE FROM WHEREVER YOU SET IT AND HAS TO BE MANUALLY ADVANCED TO SHUT OFF.
Here are your parts Parts for Roper RES7745PQ0 Dryer - AppliancePartsPros.comWhen you say is does not move in any position do you mean that it does this in both timed dry and auto modes. If yes then odds are that the timer is bad. This can be checked with a meter. If the timer moter is getting 120 volts and the timer does not advance then the timer is bad. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
