whudsonemt
#1 Posted : Sunday, September 15, 2013 2:22:45 PM(UTC)
whudsonemt
i HAVE A ROPER DRYER WHICH WORKS WELL. THE TIMER JUST DOES NOT MOVE FROM WHEREVER YOU SET IT AND HAS TO BE MANUALLY ADVANCED TO SHUT OFF.
#2 Posted : Monday, September 16, 2013 2:06:45 AM(UTC)
Parts for Roper RES7745PQ0 Dryer - AppliancePartsPros.com
When you say is does not move in any position do you mean that it does this in both timed dry and auto modes.
If yes then odds are that the timer is bad.
This can be checked with a meter.
If the timer moter is getting 120 volts and the timer does not advance then the timer is bad.
