shark1959
#1 Posted : Friday, February 10, 2012 10:48:32 AM(UTC)
shark1959
I'm writing this on behalf of a friend of mine who isn't to up on PC's and forums.
I haven't seen the problem first hand but, from talking to her it appears to make ice just fine and fills the ice bucket accordingly, it just won't dispense them. She wrote in an email to me:
"We thawed out the ice box and it would then spit out 1-2 cubes, whatever was in the chute. After that it did not have enough power to keep the dispenser turning. When I put my fingers on the coupling motor bars the force they were generating was minimal"
Is there some type of shear pin between the motor and coupling or is it some how stripped? This is my neighbours fridge so there is no problem with me doing any follow up with it, should any of you have some ideas as to what might be the cause.
Thank you in advance to your replies.
Cheers :)
Jack
#2 Posted : Sunday, February 12, 2012 4:43:31 AM(UTC)
Replacement parts for Whirlpool ED2FHEXVS00 REFRIGERATOR | AppliancePartsPros.com,
The coupler is hard connected to the motor (left hand thread).
If you click on the picture of the motor (Item 2 in Section 8) and the coupler (Item 8 in Section 8), a new page will open with more info, views and a Q&A section.
If the motor is getting 120 volts and can be easily stalled then it is probably toast.
shark1959
#3 Posted : Monday, February 13, 2012 1:38:53 PM(UTC)
shark1959
Originally Posted by: denman Go to Quoted Post
Hi Denman:
Thank you for your reply. I had a chance to look at the ice maker this past weekend and once I had it removed I could see the problem. The motor electrically is fine but, the "motor coupling" has stripped itself on the thread of the motor. I was able to use my mini grinder and cut off the coupling but, unfortuantely the threaded area of the shaft is damaged, from the the first 2 threads from the shoulder of the shaft. Because of this I don't think a new coupling it would tighten on to the motor shaft.
I was thinking if this would work. Do you know what size thread this is and whether its metric or imperial? I know it's left a left handed thread, so that's going to make this a little harder. I was wondering if I could threaded a bolt through the new coupling for a referance point and then screw a nut down onto the bolt and jam it against the coupling. Once tight I could then have it welded to the coupling, in effect extending the threaded portion of the motor coupling thread, where it would then engage with the undamaged part of the electric motor thread. I could even use a bit of thread locker to increase integrity of the connection between the two.
I don't see why this little trick wouldn't work and save me from buying a new motor, which here in Canada is close to 200$. Trick is finding the nut and bolt.
Cheers :)
Jack Roberts
#4 Posted : Tuesday, February 14, 2012 4:44:53 AM(UTC)
I would not recommend trying to weld onto the shaft.
I am not sure how badly the threads are messed up but you may be able to fix them with a small file.
If they are mashed down then perhaps you can use your rotary tool and grind them off. As long as you still have thread 3/4's of the way around the shaft it should still thread on, as long as the entrance and exit onto those threads is OK.
If you are still worried about it holding drill through the couple and the shaft and install a pin. The shaft looks about 1/4 inch so I would use a 1/16 or smaller drill.
#5 Posted : Tuesday, February 14, 2012 5:10:02 AM(UTC)
I am also a Canuck so know that getting a price close to the US price is a pain.
The motor is 2188385 replaced by 2188242
The coupler is 2205716 replaced by W10169511
Try sears canada parts sometimes their prices ar decent.
Also I did find the motor at part select canada for approx $150 delivered.
shark1959
#6 Posted : Tuesday, February 14, 2012 3:14:31 PM(UTC)
shark1959
Hi Denman:
No I wasn't going to weld anything to the motor shaft, as that could have disastrous results to the motor. What I was trying to say is welding a left handed nut (the same size and thread pitch as the motor shaft) to the coupling itself. Once cooled then screw it onto the electric motor shaft with maybe some lock tight. Doing this would give me a longer thread as to which afix the coupling to the motor shaft.
I like the idea of drilling a hole and setting a roll pin in place as well. Though kinda hard to run it straight through the shaft. I guess if you had a V-block it would work help align it.
Not sure my neighbour wants to spend that kind money on a motor just to dispense the ice. LoL
Will keep you updated on the route I take.
Thanks again for the replies.
Cheers :)
Jack
shark1959
#7 Posted : Thursday, February 16, 2012 1:00:03 PM(UTC)
shark1959
Originally Posted by: shark1959 Go to Quoted Post
Hi Denman:
Cheers :)
Jack
Hello again Denman:
I know you suggested cleaning the thread and possibly drilling the shaft and placeing a roll pin through the shaft to better secure the coupling to the the shaft.
Do you still feel strongly about the welding of a nut to the coupling (again NOT to the motor shaft) to extend the threaded portion of the coupling.
Thanks again in advance for taking the time to respond.
Cheers :)
Jack
#8 Posted : Thursday, February 16, 2012 7:17:38 PM(UTC)
No, I misunderstood your post on this.
You could weld it but finding a nut will probably be difficult.
Also the drive is probably stainless but I am not sure about that.
Also I am not sure how much this would move the bin forward or it moving it forward would effect anything.
Frigidaire FRS6LF8FS1 ice dispenser not dispensing ice (Refrigerator & Freezer Repair)
by BradASchreiber 5/31/2022 10:45:28 AM(UTC)
Whirlpool Refrigerator GD5SHAXLQ02 - Door not dispensing ice (Refrigerator & Freezer Repair)
by z-vap 3/21/2022 5:33:58 AM(UTC)
Kitchenaid Fridge Lights off Not dispensing Ice/Water (Refrigerator & Freezer Repair)
by George1234 10/14/2019 11:30:17 AM(UTC)
KitchenAid ice maker not dispensing ice (Refrigerator & Freezer Repair)
by kkranzo 7/6/2017 7:19:23 PM(UTC)
Whirlpool Gold not dispensing ice (Refrigerator & Freezer Repair)
by lbsrdi 5/20/2014 12:55:41 PM(UTC)
Ice Dispenser not dispensing ice (Refrigerator & Freezer Repair)
by dmontoya 11/18/2013 10:01:48 AM(UTC)
GE ice maker, not dispensing ice (Refrigerator & Freezer Repair)
by gleadley 5/13/2013 6:44:02 PM(UTC)
Whirlpool Refrigerator Not dispensing Ice Cubes (Refrigerator & Freezer Repair)
by lanzelot 3/12/2013 12:03:01 PM(UTC)
by iasm 1/31/2013 9:50:35 AM(UTC)
Freezer Not Dispensing Ice (Refrigerator & Freezer Repair)
by sherwelsh 10/25/2012 10:11:34 AM(UTC)
GE side/side not dispensing ice (Refrigerator & Freezer Repair)
by rlrbmw 7/29/2012 9:58:52 AM(UTC)
whirlpool modelWhirlpool #GD5NHAXASO00 not dispensing ice thru door. (Refrigerator & Freezer Repair)
by judihart 4/18/2012 6:23:44 AM(UTC)
Kitchen Aid Freezer not dispensing Ice (Refrigerator & Freezer Repair)
by trauser 3/4/2012 8:09:50 AM(UTC)
Ice maker not dispensing ice (Refrigerator & Freezer Repair)
by fourmat1 12/1/2011 1:32:51 PM(UTC)
GE Not dispensing ice, water dispensing OK (Refrigerator & Freezer Repair)
by cmonk 6/14/2011 11:54:10 AM(UTC)
