EES
#1 Posted : Thursday, February 26, 2009 2:52:10 AM(UTC)
EES
My electric dryer is not generating any heat but the drum is still running and working. As per the dryer trouble shooting guide instructions it is probably just a blown fuse case. Yesterday I purchased a Thermal Fuse in your company P/N# AP3132867 which I am about to receive within 2 to 5 days. My real problem is I dont know what part of the dryer this fuse is located at? How am I gonna install it? Did I purchased the right fuse?
A step by step guide with picture and diagrams will be greatly appreciated. This dryer purchased brand new 2 years ago and below
are the dryer's information :
ELECTRIC DRYER
NOMENCLATURE: Inglis by WHIRLPOOL CORPORATION
MODEL: IES5000RQ0
SERIAL NO: MS4112392
TYPE: DWJR-ELE-2406028-FM54
Respectfully,
Erwin Santos
551 Kings Gate
Chesapeake, Va. 23320
TechnicianBrian
#2 Posted : Thursday, February 26, 2009 5:31:06 AM(UTC)
TechnicianBrian
If your dryer is running but not heating, then you probably need a thermal cut-off kit (AP3094244) and not a thermal fuse. Both are located on the rear of the dryer behind the back panel. When the panel is removed, the heater box is on the right and the parts you get will be mounted to that housing with some thick red or red/white wires. Most likely the cut-off on the top is the one that failed, but a high limit (the one on the lower left of the box by the element) should also be replaced. When back together and working, verify your venting is not blocked, kinked or otherwise restricted as that is the reason the cut-offs fail.
dego
#3 Posted : Thursday, February 26, 2009 5:53:02 AM(UTC)
dego
sorry wrong thread
TechnicianBrian
#4 Posted : Thursday, February 26, 2009 5:54:56 AM(UTC)
TechnicianBrian
Glad it helped.
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
