the oven ignighter comes on but no gas seems to come in, and the temp stays at 75 degrees
Hi Martin,
What is the complete model number of the oven?
Gene. Hi Gene the model # as far as I know is 3488WVS
Martin, Very likely the problem is a bad (weak) igniter. If you would like you can measure the current drawn by the igniter to verify it. If the reading is 3.2 amps or less then the igniter has to be replaced. - The oven igniter Part number: AP4012072
I have the same problem how do i test the ignitor?
