Totalchef
#1 Posted : Friday, February 6, 2009 6:59:24 AM(UTC)
Totalchef
I have a KitchenAid KDS21. That will not drain. The unit Will run through all cycles. You hear the motor running like it's trying to drain. But it will not drain.
Then the unit stops. Until I vacuum the water out. After the unit runs normal until the next drain cycle.
Is there a drain solenoid that is sticking? Or the drain impeller that is clogged? Or a clogged drain pipe?
#2 Posted : Friday, February 6, 2009 7:56:32 PM(UTC)
Remove the bottom panel and check the drain hose and the check valve for a clog. If any part is broken then it is probably time for a new dishwasher because 99% of parts for this model have been discontinued and are no longer available.
Will not drain on spin cycle (Washer Repair)
by Guest 8/7/2022 8:04:16 AM(UTC)
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 3/2/2020 6:29:56 PM(UTC)
Kenmore Model 665.13269K110 will not drain (Dishwasher Repair)
by LoserKorn 4/14/2019 1:21:36 PM(UTC)
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
Samsung Front Loader will not drain (Washer Repair)
by orangecrush 4/18/2016 6:32:48 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
Whirlpool stops after wash cycle will not drain or spin (Washer Repair)
by JF2015 1/4/2015 7:19:52 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
maytag will not drain (Washer Repair)
by john rodriguez 7/15/2014 8:28:54 PM(UTC)
Maytag atlantis will not drain or spin (Washer Repair)
by Militoni 7/12/2014 3:34:57 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
Whirlpool QPII not bringing in water, also will not drain (Dishwasher Repair)
by hawkeye680 11/2/2013 9:13:43 AM(UTC)
