Tom Roberts
#1 Posted : Monday, November 28, 2011 6:58:52 AM(UTC)
Tom Roberts
Help! Kenmore top load washer. Frequently tub is out of balance on high speed dry cycle. Tub hit side of cabinet. Does this with sm and lg loads. redistributing the load does not normally correct problem. Thinking of replacing counter balance or suspension springs.
Washer was moved on its side or back. Oil was found in vehicle when unloaded. Do not hear any other noises except banging of tub hitting cabinet.
Comments would be most appreciated.
sidfink43
#2 Posted : Tuesday, November 29, 2011 5:15:46 PM(UTC)
sidfink43
You may have several problems. It sounds as though some oil has leaked out of your transmission, which will cause major problems in the future if it is not immediately replaced.
I would also change out the springs, they may have been damaged in the move.
#3 Posted : Wednesday, November 30, 2011 12:32:32 AM(UTC)
Your skateboard under the tub is out of position, remove the outer cabinet and compare the left side to the right side, then just lift up the skateboard and reposition it.
Whirlpool LER7646EQ2 drum roller banging noise (Dryer Repair)
by ultrachrome 3/6/2022 1:03:29 PM(UTC)
washer makes loud banging noise on spin cycle (Washer Repair)
by shannank77 6/27/2021 9:16:49 PM(UTC)
Whirlpool Cabrio Washer banging noise at the spin cycle (Washer Repair)
by Guest 5/13/2021 2:33:38 PM(UTC)
Dryer making banging noise (Dryer Repair)
by maytagNewbie 12/14/2017 7:14:00 AM(UTC)
Maytag Centennial banging noise while spinning mode (Washer Repair)
by afnashcom 9/13/2016 8:40:41 PM(UTC)
Washer makes loud rubbing and now banging Noise (Washer Repair)
by Topmasters 7/5/2016 5:55:02 PM(UTC)
Whirlpool Duet wash basket out of balance, making banging noise (Washer Repair)
by relentless85 1/10/2016 1:30:22 PM(UTC)
GE Washer making banging noise (Washer Repair)
by Tony2shoes 1/31/2015 4:25:26 PM(UTC)
Help My Dryer Is Making A Thumping Banging Noise (Dryer Repair)
by rkschwer 9/23/2013 6:37:25 AM(UTC)
Kenmore washer making banging noise during agitation (Washer Repair)
by daverdfw 9/3/2013 9:48:38 AM(UTC)
Maytag Performa Washer loug banging noise when stopping (Washer Repair)
by johncher 2/9/2013 2:43:39 PM(UTC)
Loud banging noise at top final spin speed (Washer Repair)
by gmlavoie 12/11/2012 10:46:43 AM(UTC)
Loud banging noise during cycle. (Trash Compactor Repair)
by Don Herman 1/17/2012 3:42:14 AM(UTC)
Loud Banging noise on way down and up (Trash Compactor Repair)
by chrisawol 11/18/2011 3:01:48 PM(UTC)
Kenmore Washer,loud banging noise (Washer Repair)
by ceking60 11/18/2011 3:30:12 AM(UTC)
