MikeZ
#1 Posted : Thursday, January 29, 2009 8:02:21 AM(UTC)
MikeZ
1) Is there any way to get the liquid back into the the balance ring?
2) Our is there some type of tube inside the ring that can be replaced?
3) I was stupid and drilled a couple of holes a couple months ago in the balance ring and liquid ran out, and the washer is always out of balance now, unless you wash small loads!!!!
I would appreciate any help on this matter.
Thank you
MikeZ
#2 Posted : Thursday, January 29, 2009 8:33:39 AM(UTC)
MikeZ
Sorry! I ment to say it is out of balance only in the spin cycle!
Thanks again
magician59
#3 Posted : Thursday, January 29, 2009 1:42:16 PM(UTC)
magician59
Better to replace it.
balance ring (Washer Repair)
by davestlc 9/17/2017 6:49:27 AM(UTC)
Samsung washer, bad balance ring? (Washer Repair)
by Branmuffin 7/12/2017 7:46:57 PM(UTC)
Outer tub bearings & Balance Ring (Washer Repair)
by subsailor 6/23/2014 3:25:12 PM(UTC)
Balance ring 3956205 tight fit (Washer Repair)
by Oldman1 4/3/2013 11:28:44 AM(UTC)
replacing the balance ring (Washer Repair)
by gbonin 1/5/2013 4:12:55 PM(UTC)
by judyjoe4250 3/19/2011 1:59:15 PM(UTC)
washer repair balance ring (Washer Repair)
by offshore1 3/13/2010 8:34:08 AM(UTC)
Balance Ring hitting Ring Tub and water on floor (Washer Repair)
by mrwto 1/26/2010 1:34:37 PM(UTC)
Top Tub and balance ring (Washer Repair)
by Patrah1 11/1/2009 2:10:58 PM(UTC)
