Your refrigerator is a side by side. The first thing I would check is the water tube in the freezer, that drops the water into the icemaker, and see if it is not frozen. If not, you have 2 water valves on that refrigerator. 1 is the before the filter water valve, and the other is after the filter water valve. If I remember right, if you take the back off the refrigerator on the bottom, if you are standing behind it, you will see the water valve, and then the second one is behind it. You need to ohm them out. If you have a meter, I can instruct you further. Tom ApplianceEducator.com
