Michele Glazer
#1 Posted : Sunday, July 29, 2007 7:20:50 AM(UTC)
Michele Glazer
My Kenmore Trio refrigerator is freezing items on the top left shelf. The setting is only at 4
#2 Posted : Wednesday, August 1, 2007 8:18:48 PM(UTC)
Michele Glazer
What items did you store on the top left shelf? This location is very close to the cold air outlet and is probably one of the coldest areas.
The temperature inside the fresh food compartment is different on different levels and you have to store food according to the temperature. It is described in the "Use and care" manual book for your fridge. If you do not have one I would recommend to order it from Sears.
What is the temperature in the freezer? May be it is too cold?
The cooling system for the fridge is located in the freezer and the fresh food compartment cools down with the air flow from the freezer.
I would recommend you to measure the temperature in the freezer and in the fresh food compartment and keep it under control.
The part number for the one of the most accurate refrigerator thermometers is AP3549145
According to FDA recommendations the temperature in the freezer suppose to be about 0 degrees and the temperature in the fresh food compartment suppose to be between 36 degrees to 40 degrees on different levels. Also keep in mind that after any temperature adjustment you have to wait about 24 hours.
Good luck.
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
Samsung Refrigerator freezing food (Refrigerator & Freezer Repair)
by Dozerxy 1/17/2022 2:30:40 PM(UTC)
GSH22JSTESS - Refrigerator Freezing Fresh Food After Replacing Main Board with WR55X10942 (Refrigerator & Freezer Repair)
by humanpowered 1/4/2020 7:19:36 AM(UTC)
GE Refrigerator Freezing Up After Replacing Main Board (Refrigerator & Freezer Repair)
by malochala 8/2/2019 1:22:43 PM(UTC)
Some areas of refrigerator freezing food (Refrigerator & Freezer Repair)
by bluefitness 10/6/2018 8:05:06 AM(UTC)
by Wingalsbeiii 12/29/2015 6:52:45 AM(UTC)
Refrigerator freezing food when ice maker working (Refrigerator & Freezer Repair)
by trout14 4/11/2015 2:57:37 PM(UTC)
Refrigerator Freezing Food on Lowest Setting (Refrigerator & Freezer Repair)
by TomMant 5/10/2014 4:25:00 AM(UTC)
by ltrager 4/2/2014 7:13:21 AM(UTC)
Refrigerator freezing food. Bottom freezer OK. (Refrigerator & Freezer Repair)
by DMand 3/11/2014 7:48:43 AM(UTC)
refrigerator freezing everything (Refrigerator & Freezer Repair)
by terryo19652009 11/26/2013 6:41:35 AM(UTC)
Samsung RB215LABP refrigerator freezing food (Refrigerator & Freezer Repair)
by Steve Dams 7/15/2013 8:50:11 AM(UTC)
Kenmore refrigerator freezing food (Refrigerator & Freezer Repair)
by onesocalguy 1/28/2013 7:42:18 PM(UTC)
freezer warm, refrigerator freezing (Refrigerator & Freezer Repair)
by westjames 1/14/2013 5:01:35 PM(UTC)
refrigerator freezing up (Refrigerator & Freezer Repair)
by cwatters60 12/4/2012 5:48:02 AM(UTC)
