My refrigerator has been freezing food for two weeks now. This problem first appeared when I noticed thawed items in the freezer. At first, I thought the door had been caught open enough to make a gap, but I never got a temperature alarm. So I rearranged the drawer and ran a power freeze on the freezer to cool it back down. After this, everything in the refrigerator began to feeze. Since then, I have cleaned the coils and vents, unplugged the unit for 12 hours to thaw with doors open, and have run the FD and RD defrost numerous times. I have not gotten any error codes in diagnostic mode (freeze and frig power freeze buttons held down together). The refrigerator temperature display flashed a few days ago, but I cleared it by unplugging the unit to reset. I did have a similar problem three years ago. Back then, I had a home warranty, and a repair company replaced the thermostat, control board, and damper door unit. Since then, Samsung sent a company to replace the parts for the Ice maker (lawsuit recall). I know the defrost heater is working ( I can hear it melting ice, and there is no ice buildup causing problems with the fan) The refrigerator is set for 44F, but the temperature inside is in the mid-’20s. Is this a thermostat problem? Whatever advice you can offer would be appreciated. Thanks in advance.
