2 Pages<12
william fischer reed
#11 Posted : Monday, October 24, 2011 12:05:44 PM(UTC)
Originally Posted by: magician59 Go to Quoted Post
Naturally, we can't tell over the internet where the oil is coming from. The gear case IS somewhat servicable; parts are available. You may get lucky as you observe the machine in operation, and see where it leaks. Just be sure to jumper the lid switch when you remove the cabinet, and the machine becomes fully operational for your inspection.
The lower section of the agitator will not lift off. It has been on there for 30years. How can I remove this section without damaging the tub?
Bill
magician59
#12 Posted : Monday, October 24, 2011 1:21:19 PM(UTC)
magician59
If you have accessed it according to either of the videos on page one of this thread, you may want to try a little WD-40 or other lubricant, and get under it with a tie-down strap or similar item, and coax it upward until it breaks free.
Use caution, as it can suddenly release and injure your face, if you're too close to it.
#13 Posted : Thursday, October 27, 2011 6:09:29 AM(UTC)
Use caution, as it can suddenly release and injure your face, if you're too close to it.[/quote .
I am still trying to get the agitator off.
I ran the washer through all the cycles Permanent, Cotton White, Cotton Color,Pre soak,, Pre Wash, Delicate and Suds.
The only cycle that engages is the Suds. The rest of the cycles it cilicks as if to engage and shows an agitating motion. If you grab the agitator, the motions stops. You can spin the agitator in reverse with no resistance.
Any suggestions?
Bill
magician59
#14 Posted : Thursday, October 27, 2011 8:37:23 AM(UTC)
magician59
It's beginning to sound like you have a worn drive block. Here's the part.
Part number: AP2905773
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
Older Kenmore Washer leak (Washer Repair)
by Guest 2/1/2024 9:56:27 AM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
Kenmore Washer spin problem (Washer Repair)
by vlherring 1/17/2023 8:10:33 AM(UTC)
Kenmore washer overflowing (Washer Repair)
by wgreene 12/21/2022 4:51:59 AM(UTC)
Kenmore washer 110 271132410 (Washer Repair)
by chris1025 12/20/2022 8:46:26 AM(UTC)
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Kenmore washer/dryer stackable combo stops (Washer Repair)
by philio22 5/1/2022 5:30:10 PM(UTC)
Kenmore Washer 110.21302013 leaving lint and hair all over clothes after several washes (Washer Repair)
by aspitale 2/12/2022 9:17:17 PM(UTC)
Kenmore washer agitation trouble (Washer Repair)
by mingmen 1/9/2022 6:01:44 PM(UTC)
Kenmore washer tub (Washer Repair)
by Guest 1/9/2022 11:21:02 AM(UTC)
Kenmore washer 796.40272900 shuts off after running about 5 minutes (Washer Repair)
by Guest 12/12/2021 2:17:32 PM(UTC)
Kenmore Washer fails to stop intermittently (Washer Repair)
by fuhrmanrl 9/22/2021 5:13:46 PM(UTC)
2 Pages<12
