barglancy
#1 Posted : Monday, September 26, 2011 4:44:08 PM(UTC)
barglancy
Dryer runs but no heat. There is no lint blockage and air flow is fine. I want to attack it myself but am unsure where to start. I replaced the electric board in a double oven last year so I'm fairly confident I can do this but was hoping for a push in the right direction. Thanks.
barglancy
#2 Posted : Tuesday, September 27, 2011 5:42:48 AM(UTC)
barglancy
Looks like a coil issue so I've ordered the parts from here. How do I gain access to the burner assembly? Does the top need to come off so I can remove the front?
barglancy
#3 Posted : Tuesday, September 27, 2011 8:54:46 AM(UTC)
barglancy
If anyone else has trouble accessing their dryer here's a step by step.
29" Dryer Gas Valve Solenoid Coil Kit Replacement (part #279834) - YouTube
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Dryer runs but no heat. (Dryer Repair)
by Elarde 6/18/2015 1:17:00 AM(UTC)
Electric dryer runs but no heat (Dryer Repair)
by M hatcher 1/28/2015 2:49:23 PM(UTC)
new kenmore dryer runs but no heat (Dryer Repair)
by crazyhouse 11/19/2012 4:56:14 PM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
another "dryer runs but no heat" problem (Dryer Repair)
by Rayman812 6/27/2011 7:31:38 PM(UTC)
Whirlpool Gas Dryer Runs But No Heat (Dryer Repair)
by cybolt 3/10/2011 8:08:45 PM(UTC)
by sdean 2/8/2011 2:05:25 PM(UTC)
Gas dryer runs but no heat (Dryer Repair)
by pastrychef 1/31/2011 9:02:20 PM(UTC)
Gas dryer runs but no heat. (Dryer Repair)
by peter g 1/7/2011 9:32:32 PM(UTC)
Dryer runs but no heat (Dryer Repair)
by glenn906 7/1/2010 11:14:54 AM(UTC)
Frigidare gas dryer runs but no heat or ignition (Dryer Repair)
by hanzi1 5/21/2010 12:06:37 PM(UTC)
by katyld 1/27/2010 3:06:34 PM(UTC)
by je24995 12/13/2009 11:19:31 AM(UTC)
Roper,dryer runs but no heat. (Dryer Repair)
by JOE BLACK 9/19/2009 1:39:36 PM(UTC)
