layitonme
#1 Posted : Saturday, January 3, 2009 4:29:15 PM(UTC)
layitonme
While replacing the bolt/washer that holds the agitator down on my older Kenmore top load, I cannot tighten it due to the shaft underneath turning with it. What am I suppose to do to tighten it all of the way?
#2 Posted : Sunday, January 4, 2009 2:51:12 AM(UTC)
Make sure the agitator is down all the way and hold it while tighening the bolt. If it still will not tighten, you have a stripped spine on the tranny shaft.
layitonme
#3 Posted : Sunday, January 4, 2009 7:52:28 AM(UTC)
layitonme
Thanks. I took the agitator off again and inspected the spines and, althought alittle worn, there are none broken. The inside of the agitator where the shaft fits up into does appear to be worn flat though. If that's the case, would replacing the agitator fix the problem and what should I expect to pay?
#4 Posted : Monday, January 5, 2009 12:30:39 AM(UTC)
Available on this site, ap3114127 about $44 plus shipping.
Agitator repair or replacement and HE??? (Washer Repair)
by DougKathleen 8/28/2011 4:07:25 PM(UTC)
washer agitator repair (Washer Repair)
by brigid lamburth 8/9/2011 3:09:15 AM(UTC)
Agitator Repair (Washer Repair)
by jr71fs 8/4/2011 11:57:59 AM(UTC)
Agitator repair parts (Washer Repair)
by wildesrr 4/17/2011 11:35:09 AM(UTC)
Maytag agitator repair (Washer Repair)
by macphersgr 3/27/2011 5:50:58 AM(UTC)
Agitator Repair Kit (Washer Repair)
Belarus bernyg 2/12/2010 9:26:55 AM(UTC)
agitator repair kit (Washer Repair)
by kstatefan 10/9/2009 1:44:14 PM(UTC)
Which cam size for Agitator repair? (Washer Repair)
by rdeford 3/5/2009 5:28:04 PM(UTC)
trying to replace dogs (agitator repair kit) (Washer Repair)
by carolinamae 11/21/2008 4:50:53 PM(UTC)
Agitator repair kit thrust washer grease (Washer Repair)
by Imbobman 11/28/2007 9:38:56 AM(UTC)
Agitator Repair kit (Washer Repair)
by eightball1011 11/12/2007 9:18:04 AM(UTC)
