oddg241
#1 Posted : Saturday, December 27, 2008 12:55:56 PM(UTC)
oddg241
I have a Sears Kenmore electric dryer. The dryer will spin but not heat. I have removed heat element, a 250 degree thermostat attached to heater element cover, and removed the thermostat cut off (hi-limit thermostat). All of them read continuity. Can a thermostat read good but still be bad? The 250 degree thermostat regulates the heat element? The hi-limit shuts it off if over 250 degrees? I lose one side of 220VAC fuses. Sometimes right side, sometimes both sides.
oddg241
#2 Posted : Saturday, December 27, 2008 2:16:51 PM(UTC)
oddg241
I have unhooked 250 degree thermo from heat element box, I was reading each post before. Now my heat element reads 9.6 ohms on a Fluke digital meter. That is not an acceptable reading, is it?
#3 Posted : Sunday, December 28, 2008 10:22:18 AM(UTC)
Check the wall outlet for 230 volts across the outer two pins.
oddg241
#4 Posted : Sunday, December 28, 2008 3:59:55 PM(UTC)
oddg241
I have 220 to plug. I read 110 each leg, and 220 across them. ty for the tip.
#5 Posted : Monday, December 29, 2008 12:15:30 AM(UTC)
Run the dryer with the back off and check for 230 volts across the thermal fuse, overload thermostat and cycling thermostat.
oddg241
#6 Posted : Monday, December 29, 2008 7:30:44 AM(UTC)
oddg241
I only see a place for 2 thermostats. One attached right by heater element and one higher up the duct, the hi limit thermostat. Where is thermol fuse located?
#7 Posted : Tuesday, December 30, 2008 12:15:45 AM(UTC)
The thermal fuse has a ceramic base and high up on the heater housing, cycling thermostat on the blower housing.
oddg241
#8 Posted : Friday, January 2, 2009 7:32:16 PM(UTC)
oddg241
In my second post I read 9.6 ohms on heater element. Is that a good element or should it read infinity on continuity?
oddg241
#9 Posted : Saturday, January 3, 2009 11:06:30 AM(UTC)
oddg241
Sorry. I said that wrong in last reply. I meant zero not infinity. Today I found the thermal fuse and it reads 0. I found the Internal Bias Thermostat, it has 4 posts, the larger 2 (top and bottom) and smaller 2 (left and right sides). I read zero from top to bottom posts. I read nothing on smaller posts to each other, or in any combination with larger posts and either smaller posts. Is that a correct reading? Am I supposed to be able to read small post to small post?
Guest (5)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
