3 Pages<123
hommebr
#21 Posted : Sunday, August 14, 2011 4:35:04 PM(UTC)
hommebr
i put the new boards in and the light remained red and no ice. any other thoughts?
#22 Posted : Sunday, August 14, 2011 4:44:31 PM(UTC)
Is it blinking now or it's solid?
hommebr
#23 Posted : Monday, August 15, 2011 10:37:17 AM(UTC)
hommebr
when the door is open the light on the right blinks twice and then repeates itself, note the light is RED. When I hold the flap closed on the left side it is a solid RED light.
#24 Posted : Monday, August 15, 2011 5:42:08 PM(UTC)
Bruce,
Per your post back in May it was blinking wherever the emitter door was open or closed. Now it does what it suppose to. So, we can assume that optics are fine now.
Is the "on-off" switch in on position?
Make sure the water feeding tube into the ice maker is not frozen. Locate the water inlet valve on the back of the refrigerator. Swap the wires between the green and red (orange) solenoids. Depress the water dispenser lever for a few seconds and check if there is water in the ice maker. Post the results.
P.S. The LED does not change its color for any condition. If it's red then it was made red by the manufacturer.
hommebr
#25 Posted : Friday, August 19, 2011 9:31:12 AM(UTC)
hommebr
when I did as you suggested and then pressed the water dispenser on the outside of the ref. water filed the ice tray.
#26 Posted : Saturday, August 20, 2011 5:03:38 PM(UTC)
That means there is nothing wrong with the water valve and the problem is that the power to the water valve is not coming from the ice maker. The solution is to replace the ice maker.
- The ice maker Part number: AP3182733
hommebr
#27 Posted : Tuesday, September 20, 2011 3:07:15 PM(UTC)
hommebr
i put the new ice maker in and it filled the ice tray with water but it would not eject the ice. I then took the ice maker out again removed the frozen water and reinstalled. The same thing happened, could I have gotten a bad ice maker?
Guest (11)
Kitchenaid Ice Maker Lever Problem (General Talk)
by Guest 11/4/2021 10:00:56 PM(UTC)
Kitchenaid ice maker help (Refrigerator & Freezer Repair)
by Fridge276 7/31/2020 3:09:46 AM(UTC)
KitchenAid Ice Maker won't stop turning. (Refrigerator & Freezer Repair)
by slipsibm 5/30/2020 10:15:54 AM(UTC)
KitchenAid ice maker - ice sometimes slides into reservoir pan rather than onto cutter grid (Refrigerator & Freezer Repair)
by thall88 12/7/2018 1:59:31 PM(UTC)
KitchenAid ice maker not dispensing ice (Refrigerator & Freezer Repair)
by kkranzo 7/6/2017 7:19:23 PM(UTC)
Kitchenaid Ice Maker Issue (Refrigerator & Freezer Repair)
by phillyphan 5/29/2017 1:06:55 PM(UTC)
KitchenAId Ice Maker not working (Refrigerator & Freezer Repair)
by mmciel 12/21/2012 8:28:40 PM(UTC)
KitchenAid ice maker not working (Refrigerator & Freezer Repair)
by lizprimary 12/15/2012 2:42:41 PM(UTC)
Icicle forming underneath KitchenAid ice maker (Refrigerator & Freezer Repair)
by AaronGo 10/15/2012 5:28:19 PM(UTC)
by East Texas 4/25/2012 11:06:10 AM(UTC)
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 3/4/2012 12:49:54 PM(UTC)
kitchenaid ice maker not working (Refrigerator & Freezer Repair)
by laurn 12/19/2011 6:44:32 PM(UTC)
Dripping KitchenAid Ice Maker (Refrigerator & Freezer Repair)
by tonymarch 9/8/2011 5:16:52 AM(UTC)
Kitchenaid Ice Maker (Refrigerator & Freezer Repair)
by b015dwj 7/14/2011 5:28:02 AM(UTC)
by pistilli777 10/26/2010 11:51:01 AM(UTC)
3 Pages<123
