I have a side by side unit and the water works but the ice maker stopped making ice. Can anyone help?
When I do as you asked I get a red blinking light. Also the unit is making some ice now but is not ejecting it.
How does it blink? Try to be as much detailed as possible.
Gene, I appreciate you getting back to me. The red light blinks in a series of 2 red blinks, pauses, and then it repeats itself. Bruce
Gene, Today when I got home the light indicator on the freezer was not working at all, could it still be the same problem? Also where are these boards located and how do I get to them? Thank you Bruce
Originally Posted by: hommebr  ...could it still be the same problem?...
...Also where are these boards located and how do I get to them?...
Bruce, Yes, it could. Please click on the "diagram" in the previous reply and look for ## 26 & 38. Gene.
Gene, Just getting back to the freezer trouble again and before I order the parts that you recommended I looked at the light again and now it is staying on but red and i do get an ice cube occassionally. Do you still recommend changing these parts? Bruce
Bruce,
What is the exact temperature in the freezer?
