My icemaker stopped working and I ordered a new module 3 times from appliancepartspros. After 3 attempts i purchased the entire unit and it still will not dispense ice after 3 days. It is feeding the ice tray and there is water thru the door. I checked the optics and it is working fine. What else can be the problem?
Originally Posted by: pistilli777  My icemaker stopped working and I ordered a new module 3 times from appliancepartspros. After 3 attempts i purchased the entire unit and it still will not dispense ice after 3 days. It is feeding the ice tray and there is water thru the door. I checked the optics and it is working fine. What else can be the problem? It will not dispense ice through the freezer door or from the ice maker into the ice bin? Gene.
Originally Posted by: pistilli777  yes, that is correct...
Gene are you there today???
Originally Posted by: pistilli777  My icemaker stopped working and I ordered a new module 3 times from appliancepartspros. After 3 attempts i purchased the entire unit and it still will not dispense ice after 3 days. It is feeding the ice tray and there is water thru the door. I checked the optics and it is working fine. What else can be the problem? Can anyone help me with this???
