3 Pages<123
hommebr
#21 Posted : 14 years ago
hommebr
i put the new boards in and the light remained red and no ice. any other thoughts?
#22 Posted : 14 years ago
Is it blinking now or it's solid?
hommebr
#23 Posted : 14 years ago
hommebr
when the door is open the light on the right blinks twice and then repeates itself, note the light is RED. When I hold the flap closed on the left side it is a solid RED light.
#24 Posted : 14 years ago
Bruce,
Per your post back in May it was blinking wherever the emitter door was open or closed. Now it does what it suppose to. So, we can assume that optics are fine now.
Is the "on-off" switch in on position?
Make sure the water feeding tube into the ice maker is not frozen. Locate the water inlet valve on the back of the refrigerator. Swap the wires between the green and red (orange) solenoids. Depress the water dispenser lever for a few seconds and check if there is water in the ice maker. Post the results.
P.S. The LED does not change its color for any condition. If it's red then it was made red by the manufacturer.
hommebr
#25 Posted : 14 years ago
hommebr
when I did as you suggested and then pressed the water dispenser on the outside of the ref. water filed the ice tray.
#26 Posted : 14 years ago
That means there is nothing wrong with the water valve and the problem is that the power to the water valve is not coming from the ice maker. The solution is to replace the ice maker.
- The ice maker Part number: AP3182733
hommebr
#27 Posted : 14 years ago
hommebr
i put the new ice maker in and it filled the ice tray with water but it would not eject the ice. I then took the ice maker out again removed the frozen water and reinstalled. The same thing happened, could I have gotten a bad ice maker?
Kitchenaid Ice Maker Lever Problem (General Talk)
by Guest 3 years ago
Kitchenaid ice maker help (Refrigerator & Freezer Repair)
by Fridge276 5 years ago
KitchenAid Ice Maker won't stop turning. (Refrigerator & Freezer Repair)
by slipsibm 5 years ago
KitchenAid ice maker - ice sometimes slides into reservoir pan rather than onto cutter grid (Refrigerator & Freezer Repair)
by thall88 6 years ago
KitchenAid ice maker not dispensing ice (Refrigerator & Freezer Repair)
by kkranzo 8 years ago
Kitchenaid Ice Maker Issue (Refrigerator & Freezer Repair)
by phillyphan 8 years ago
KitchenAId Ice Maker not working (Refrigerator & Freezer Repair)
by mmciel 12 years ago
KitchenAid ice maker not working (Refrigerator & Freezer Repair)
by lizprimary 12 years ago
Icicle forming underneath KitchenAid ice maker (Refrigerator & Freezer Repair)
by AaronGo 12 years ago
by East Texas 13 years ago
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 13 years ago
kitchenaid ice maker not working (Refrigerator & Freezer Repair)
by laurn 13 years ago
Dripping KitchenAid Ice Maker (Refrigerator & Freezer Repair)
by tonymarch 14 years ago
Kitchenaid Ice Maker (Refrigerator & Freezer Repair)
by b015dwj 14 years ago
by pistilli777 14 years ago
3 Pages<123
