beachrunner
#1 Posted : Monday, August 15, 2011 8:56:07 AM(UTC)
beachrunner
just replaced element and thermostat still wont heat up
#2 Posted : Saturday, August 20, 2011 5:56:40 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for ADMIRAL ADE7000AYW DRYER- ELE | AppliancePartsPros.com
Note: the REI on the lower right side is actually connected to L2.
I would start by checking the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Whirlpool Inglis Dryer Wont Heat Up and Keeps Running (Dryer Repair)
by johnnymac813 1/8/2014 4:39:14 PM(UTC)
Dryer Wont Heat Up (Dryer Repair)
Belarus SUE KLEIN 8/24/2013 6:22:08 AM(UTC)
dryer wont heat up (Dryer Repair)
by lmyers 3/11/2013 12:31:55 PM(UTC)
Gas dryer wont heat up (Dryer Repair)
by kramler92 12/8/2011 3:14:26 PM(UTC)
Neptune Dryer wont heat up or dry (Dryer Repair)
by medik3 8/4/2011 8:13:36 AM(UTC)
dryer wont heat up at all (Dryer Repair)
by dcquick1096 12/2/2010 7:30:44 AM(UTC)
Dryer wont heat up (Dryer Repair)
by ktventura1989@yahoo.com 7/9/2010 2:32:48 PM(UTC)
Whirlpool Elec Dryer wont heat up (Dryer Repair)
by Canute 2/9/2010 3:16:11 PM(UTC)
by tam4572@aol.com 2/7/2010 3:22:11 AM(UTC)
dryer wont heat up? (Dryer Repair)
by jreich77 11/1/2009 4:33:01 PM(UTC)
by trish949 9/26/2009 7:33:08 AM(UTC)
Ge dryer wont heat up (Dryer Repair)
by CLARK12 8/2/2009 12:36:31 PM(UTC)
by poelease 6/4/2009 8:22:16 AM(UTC)
by NYSE Bob 5/21/2009 5:33:26 PM(UTC)
Whirlpool Imperial series gas dryer wont heat up.. (Dryer Repair)
by NBK 4/6/2009 3:36:45 PM(UTC)
