PLS HELP..MY WASHER NOT SPINNING BUT I HEARD THE MOTOR WORKING.IT FILL WATER . IS IT POSSIBLE THE AGITATOR NOT WORKING..OR CLUTCH NOT WORKS, OR SOME WHERE..WHEN I TURN THE KNOB CONTROL TO SPINNER ..THE AGITATOR NOT SPINNING ..BUT I HEARD THE MOTOR WORKING ..HELP:confused:
My Washer Not Spinning..agitator Not Working.motor Works .it Fills Up Water,when I Set My Knob To Spin I Only Heard Motor Working..i Dunno Where To Trouble Shoot First..is It Possible The Clutch,brake,agitator Switch.or Somewhere..pls Help
As stated before. Originally Posted by: libertyappl
Originally Posted by: libertyappl my question now how can i remove the coupler of my washer. and said bet. the pump and motor..is that kind of hard and complicated.,is another way to make it simple to take and replace a new coupler..can you simplify and explain it brief how to dig it..is that under nit or in the very bottom of my washer
