frankie40
#1 Posted : Thursday, December 18, 2008 7:57:07 AM(UTC)
frankie40
PLS HELP..MY WASHER NOT SPINNING BUT I HEARD THE MOTOR WORKING.IT FILL WATER . IS IT POSSIBLE THE AGITATOR NOT WORKING..OR CLUTCH NOT WORKS, OR SOME WHERE..WHEN I TURN THE KNOB CONTROL TO SPINNER ..THE AGITATOR NOT SPINNING ..BUT I HEARD THE MOTOR WORKING ..HELP:confused:
libertyappl
#2 Posted : Thursday, December 18, 2008 8:00:13 AM(UTC)
libertyappl
Sounds like your coupler broke.
Here's the breakdown of your unit. Model LSR8233EQ1
The coupler is located between the pump & motor.
Part- Motor coupling (for direct drive washers)
Hope this helps
Nat
frankie40
#3 Posted : Thursday, December 18, 2008 8:02:21 AM(UTC)
frankie40
My Washer Not Spinning..agitator Not Working.motor Works .it Fills Up Water,when I Set My Knob To Spin I Only Heard Motor Working..i Dunno Where To Trouble Shoot First..is It Possible The Clutch,brake,agitator Switch.or Somewhere..pls Help
libertyappl
#4 Posted : Thursday, December 18, 2008 8:16:09 AM(UTC)
libertyappl
As stated before.
Hope this helps
Nat
frankie40
#5 Posted : Sunday, December 21, 2008 7:27:19 PM(UTC)
frankie40
Hope this helps
Nat
my question now how can i remove the coupler of my washer. and said bet. the pump and motor..is that kind of hard and complicated.,is another way to make it simple to take and replace a new coupler..can you simplify and explain it brief how to dig it..is that under nit or in the very bottom of my washer
#6 Posted : Monday, December 22, 2008 12:56:12 AM(UTC)
Go to www.applianceaid.com for info.
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
MAYTAG MHWC7500Y WASHER NOT SPINNING AT HIGH SPEED (Washer Repair)
by ehbrown1 11/5/2019 4:50:11 AM(UTC)
Stacked Maytag/Neptune Washer not spinning (Washer Repair)
by Building and Grounds 10/24/2017 12:26:37 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
Whirlpool washer not spinning fast (Washer Repair)
by AmyM269 9/3/2016 4:22:47 PM(UTC)
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
Washer not spinning after replacing Thrust Bearing Kit (Washer Repair)
by Woody Williams 2/25/2014 2:06:33 PM(UTC)
