13 Pages«<910111213>
jgindi
#101 Posted : Tuesday, June 7, 2011 9:15:32 AM(UTC)
jgindi
Hi All,
I have a GE Adora whdvh626fww. It has stopped agitation and spinning. I moved, and took the unit with me. Once I installed the washer in the new house it did not work. I am not sure how to diagnose the problem or how to fix it. Any help would be greatly appreciated.
Thanks,
Jake
#102 Posted : Tuesday, June 7, 2011 4:43:34 PM(UTC)
Jake,
Did it work before you moved?
Does it fill with water?
Try to run the Service mode as instructed on page 9 of this thread.
Here are the breakdown diagrams and Replacement parts for General Electric WHDVH626F0WW Washer | AppliancePartsPros.com
tmw923
#103 Posted : Sunday, June 12, 2011 12:13:05 PM(UTC)
tmw923
I am currently have the same problem. My washer worked fine yesterday and now it won't spin. When I noticed the closed did not spin, i put it on Drain and spin. It started like it was working then nothing. It unlocked as if it was done. Can someone please give me some advise as what to try to fix it.
Tammy
#104 Posted : Monday, June 13, 2011 5:09:41 PM(UTC)
Tammy,
What is the complete model number of the washer?
mole65
#105 Posted : Sunday, August 14, 2011 5:58:10 PM(UTC)
mole65
Hi Gene,
I have a WBVH6240FWW, and of course, similar issues to everyone else's problems, where the unit will no longer do any spinning. I have reset the control board, run through the self tests:
t01 - reset to #3
t02 - error code E54 only
t03 - cod 100, EE 13, inv 143
t04 - run through cycle 012, 123, 234, 345, 456, 567, 678, 789, 890 (all seemed to work)
t05 - displayed P and ran for about 1 min, then return to t05
t06 - ran to all levels and emptied, seemed fine
t07 - I did not perform
t08 - I did not perform
t09 - I did not peform
t10 - displays tt, does nothing, did not see any 120v reading at blue/red pins to inverter
t11 - shows 0, does nothing, no 120V at inverter
t12 - I did not perform
t13 - I did not perform
t14 - shows 0, does nothing, no 120V at inverter
I did check the motor resistance and shows 6 ohms across the three wire combinations, and sensor checks okay at 118 ohms. The only time I see 120V go to the red/blue input supply to the inverter is when I have the unit in normal run operation, start a wash cycle, the door will lock, unlock, lock, then the input to the inverter will slow ramp to about 112 V, then stop, then slow ramp again to about 112V, then stop, the drum will jerk slightly, and the unit will drain and stop working (flashing light on Start/Pause button).
I'm not sure if this leads to a bad inverter, or a bad control board output to the inverter. With a house of a wife and 3 daughters I need to make sure laundry can be done. Any help is appreciated!
thanks
#106 Posted : Monday, August 15, 2011 5:28:01 PM(UTC)
More likely the problem is a bad control board because it does not supply proper AC voltage to the inverter.
- The control board Part number: AP3995160
mole65
#107 Posted : Monday, August 15, 2011 5:59:06 PM(UTC)
mole65
Hi Gene,
Thanks for the input. Quick question, is it suppose to be supplying 120V to the inverter at all times while on? or only at specific times?
Thanks.
#108 Posted : Monday, August 15, 2011 6:01:40 PM(UTC)
It suppose to supply 120 VAC only when the motor should be on.
Irontan
#109 Posted : Monday, August 29, 2011 9:47:52 PM(UTC)
Irontan
We have a similar problem...but I can't even figure out how to get into service/test mode. We have a ge wcvh6800jww that is just over a year old and seems to pause mid cycle leaving us with a pile of soaking wet clothes. We cleaned the filter, and it seems to drain. It will spin on the drain and spin cycle (but it takes about an hour instead of 12 minutes).
Please help!
Thanks!
#110 Posted : Tuesday, August 30, 2011 3:31:28 PM(UTC)
Look for the Tech sheet behind the bottom service panel or under the top panel.
Guest (16)
ge front load washer won't tumble/spin (Washer Repair)
by Laeloni 3/26/2011 10:07:27 AM(UTC)
