geraki
#1 Posted : Thursday, December 11, 2008 10:08:47 AM(UTC)
geraki
Yesterday the timer didn't advance. We moved the knob to short wash and it did finished. Unfortunately, today it happened the same thing. It stayed in wash cycle for hours. We assume that the internal timer is the only thing that can create this problem right? Is anyone knows the part number for the timer and if there is any instructions how to install it?
Thanks. :)
Drags1998
#2 Posted : Thursday, December 11, 2008 11:27:57 AM(UTC)
Drags1998
Is the "HIGH TEMP WASH" button pushed??? Is the incoming water HOT??? The timer has a PAUSE in it tp heat the water if its not HOT enough.:)
geraki
#3 Posted : Thursday, December 11, 2008 12:10:22 PM(UTC)
geraki
The first time that this happen the "high temp wash" was on. We turned off and moved it to short wash and the cycle was finished. The 2nd time that happened it was on "normal wash", no "high temp wash". When I opened the door after I realize the timer was not moving, the dishwasher was hot, the soap was not there, and it looked that the dishes were washed!!! Should and how can I check if the incoming water is hot?
Thanks for your reply :)
#4 Posted : Thursday, December 11, 2008 1:05:17 PM(UTC)
Here is your parts breakdown
Model GSD3220Z02BB
Is probably the timer unless the lights on the door were out then it is probably a door switch just making contact.
Fairly simple to replace just remove the inner door liner and you will be see.
One thing to watch and/or make yourself pictures is how the cam and lever are hooked up to open your soap dish. Note where the spring attaches etc.
A digital camera can also help here.
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
Timer will not advance (Dryer Repair)
by Mechris 10/25/2016 6:30:42 AM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
by stevechar 9/21/2014 8:33:08 AM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Timer will not advance after lightning strike (Dryer Repair)
by jwahl16 9/3/2014 2:23:07 PM(UTC)
New timer will not advance (Washer Repair)
by meganbella 4/5/2013 7:02:18 AM(UTC)
GE washer timer will not advance. (Washer Repair)
by Chumlord 6/29/2010 2:52:09 PM(UTC)
Dryer timer will not advance (Dryer Repair)
by Brian7780 6/19/2010 7:23:44 AM(UTC)
Timer will not advance in cool down part of cycle (Dryer Repair)
by Blake1111 3/30/2010 2:00:14 PM(UTC)
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 (Washer Repair)
by ambsdr4god 11/8/2009 4:12:08 PM(UTC)
Timer will not advance in Auto Dry (Dryer Repair)
by KSherer 6/2/2009 6:17:52 PM(UTC)
Maytag timer will not advance (Washer Repair)
by Robinscs 2/18/2009 2:40:20 PM(UTC)
Dryer Timer Will Not Advance (Dryer Repair)
by cyclone 1/15/2009 9:42:24 AM(UTC)
