fred2117
#1 Posted : Monday, December 8, 2008 4:25:08 PM(UTC)
fred2117
I just tried Putting a load in my Dryer and my coat zipper got caught in door and on little Black thing on upper right corner, now my dryer won't start, What is this thing and how hard to replace?
#2 Posted : Tuesday, December 9, 2008 2:16:00 AM(UTC)
A model number might help
I believe you are talking about the door switch activator.
There is a switch inside the machine that must be closed for the unit to run.
If it is a little clip that has bust off snaps into the door, you will have to replace it.
If it is a metal actuator you may be able to re-bend it so the door closes the switch, just be gentle. The actuator is often mounted to the switch which is plastic.
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Whirlpool Estate Dryer (Dryer Repair)
by Bob Castles 6/11/2016 1:26:44 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
Estate dryer won't heat, all the thermosats and heating elements good (Dryer Repair)
by Tim2020 4/26/2014 7:52:57 PM(UTC)
estate dryer wont shut off (Dryer Repair)
by centerville1966 2/15/2014 1:39:29 PM(UTC)
Estate dryer not heating up (Dryer Repair)
by Jackier 8/6/2013 5:23:00 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Estate dryer looses flame once it hits the 40 min spot on dial (Dryer Repair)
by goetso 11/14/2012 1:29:27 PM(UTC)
Estate dryer won't start, replaced thermal fuse still not working (Dryer Repair)
by cassnbruce52607@aol.com 11/10/2012 6:04:51 PM(UTC)
Estate Dryer Heats Up But Motor Stopped (Dryer Repair)
Belarus krSRinPA 7/5/2012 7:22:14 AM(UTC)
Estate Dryer will not start (Dryer Repair)
by drew63 6/18/2012 11:11:18 AM(UTC)
Whirlpool estate dryer making noise (Dryer Repair)
by sullivanwi1 6/2/2012 7:19:36 AM(UTC)
by kbollen 3/21/2012 6:57:44 PM(UTC)
whirlpool estate dryer (Dryer Repair)
by estatedryer 12/29/2011 4:26:21 PM(UTC)
by steven acer 12/18/2011 4:34:53 PM(UTC)
