lmreese25
#1 Posted : Saturday, February 9, 2013 8:06:34 PM(UTC)
lmreese25
I have an estate dryer that will not start. It was working fine then just wouldn't start anymore. We had temporarily replaced the dryer with an old one from a friend. That dryer worked perfectly. This tells me it is not an electrical issue within the house itself. I have tested the thermal fuse by disconnecting the wires and touching them together. I have tested the start button by disconnecting the wires and touching them together. I have also tested the door switch by straight wiring. Nothing has worked so far and the timer makes a faint clicking sound, confirming it is getting power and obviously working. What else can it be?
#2 Posted : Sunday, February 10, 2013 1:24:23 AM(UTC)
A model number may help others help you.
Need to find a wiring diagram.
