targetbill
#1 Posted : Saturday, December 6, 2008 5:05:35 PM(UTC)
targetbill
Dryer was working fine earlier in the day. We had a transformer blow in the area and lost power for a couple hours. NOw the power is back on, the breakers are fine, the drum light works, the dial lights work, but the dryer will not run. NO humming, nothing. Drum spins by hand with resistance so belts seems to be OK. Any ideas would be helpful. 5 kids lots of laundry!!:)
kayakcrzy
#2 Posted : Sunday, December 7, 2008 8:19:16 AM(UTC)
kayakcrzy
UserPostedImage
This is the thermal fuse it is mounted on the heater housing. This could shut the whole unit down. It could be the door switch too, but, with a surege, it is most likely, the thermal fuse. Be sure the unit has power. Tom ApplianceEducator.com
#3 Posted : Sunday, December 7, 2008 11:21:54 AM(UTC)
Here is your parts breakdown
Model MDET446AYW
Here is a tech sheet and a service manual all be not much of a service manual
http://www.servicematters.com/m...ibrary/docs/16027523.pdf
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
Hopefully it is the switch or fuse.
The unit has a circuit board and the fastest fuse in the world is an electronic component. They will blow long before a fuse starts to melt. If it is the main board you may want to inquire at your hydro company. I know our company will compensate if they cause the problem re: brown outs etc.
Turn your breaker off/on slowly or better yet check it with a meter for 240 volts. Could be you have lost half your line.
On most units the lights and the motor use the same side of the line. Yours looks like it uses L1 for the lights but L2 for the motor.
Often half the line can drop out and not blow the breaker.
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Kitcheaid superba died after power surge (Microwave Repair)
by jswol 2/17/2021 4:53:30 PM(UTC)
Bosch Dishwasher - lightening strike power surge (Dishwasher Repair)
by bendermichael76 11/3/2018 6:28:35 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
power surge furnace dead now (Heating, Ventilation, and Air Conditioning (HVAC))
by mutineer 9/15/2016 1:53:26 PM(UTC)
bosch dishwasher power surge (Dishwasher Repair)
by harry32 6/19/2015 6:27:07 AM(UTC)
GE Dishwasher doesn't work after power surge (Dishwasher Repair)
by utpal 4/28/2015 4:51:33 AM(UTC)
Power surge...no power now (Oven Repair (including Ranges and Cooktops))
by KURT HUTSON 12/21/2014 1:45:44 PM(UTC)
Power Surge Killed Oven (Oven Repair (including Ranges and Cooktops))
by Fathergoose007 9/7/2014 1:13:25 PM(UTC)
Power surge and microwave teoubles (Microwave Repair)
by mr.ken 8/25/2014 4:59:04 PM(UTC)
Power surge knocked out oven (Oven Repair (including Ranges and Cooktops))
by Jiminedmond 7/3/2014 8:52:46 AM(UTC)
power surge-- refrigerator not working.. reset button? (Refrigerator & Freezer Repair)
by nashes48 12/26/2013 4:30:18 PM(UTC)
Power Surge Hobbled Fridge (Refrigerator & Freezer Repair)
by Korpps 11/19/2013 5:21:53 AM(UTC)
Power Surge On Frigidaire Diswasher acting funny (Dishwasher Repair)
by praze4life 7/26/2013 9:19:15 PM(UTC)
Not working after power surge (Washer Repair)
by TP26 3/12/2013 11:44:57 AM(UTC)
