KURT HUTSON
#1 Posted : Sunday, December 21, 2014 1:45:44 PM(UTC)
KURT HUTSON
Had a power surge...now no power to the cooktop...checked breakers..all good.
Could it be fuse or breaker of some sort inside the cooktop.
if so any help where it is located would be much appreciated:)
#2 Posted : Monday, December 22, 2014 2:08:49 AM(UTC)
Parts for Whirlpool G9CE3065XB00 Cooktop - AppliancePartsPros.com
You will have to check the power to the unit with a meter.
Below is my usual blub.
Depending how the unit is wired some of it may not be applicable.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
G9CE.pdf (316kb) downloaded 3 time(s).
