I have a len1000pq1 dryer the heat is not working and the timer doesnt move could that be the timer for both problems, the dryer does run
Originally Posted by: nwiccauto I have a len1000pq1 dryer the heat is not working and the timer doesnt move could that be the timer for both problems, the dryer does run Nwiccauto, The timer, could be the problem, and a very good guess. Part number: AP3131541
But, I would suspect a malfunctioning motor switch or damaged white/black wire from the motor. Part number: AP3094245
The motor supplies the L2 power to both the heater and timer motor, and is a more likely failure at this point. Good Luck, :) :) :)
