Dunderdown
#1 Posted : Monday, June 13, 2011 12:39:56 PM(UTC)
Dunderdown
Started leaking just a little but now it seems that full load worth of water is coming out. I checked supply and drain lines and they're dry. what's the next place to check?
#2 Posted : Tuesday, June 14, 2011 3:24:42 AM(UTC)
The model number does not come up.
Kenmore numbers are usually 3 digit, a period and the 8 more digits.
Dunderdown
#3 Posted : Tuesday, June 14, 2011 10:13:55 AM(UTC)
Dunderdown
#159711 / 15942
Dunderdown
#4 Posted : Tuesday, June 14, 2011 10:14:50 AM(UTC)
Dunderdown
Kenmore # 15944 / 15942
#5 Posted : Wednesday, June 15, 2011 12:29:35 AM(UTC)
Sorry but I cannot find any info on this unit.
I can only suggest removing the kick plate and checking what is leaking.
A flashlight and a small mirror help here.
The type of mirror mechanics use sort of like a dentist's mirror but larger is ideal but you could tape a small one on the end of a wood dowel.
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
REFRIGERATOR IS LEAKING WATER (Refrigerator & Freezer Repair)
by Guest 8/9/2023 9:19:28 AM(UTC)
Leaking Water (Washer Repair)
by KATHYk 2/11/2017 11:03:08 AM(UTC)
Leaking Water Valve W10340983 (Refrigerator & Freezer Repair)
by doubldc 2/9/2017 9:40:08 PM(UTC)
Kenmore Series 80 washer leaking water above clutch assembly (Washer Repair)
by hallway 2/5/2017 1:48:24 PM(UTC)
Leaking Water Supply Tube At Valve (Refrigerator & Freezer Repair)
by PENZZZ 10/5/2016 5:57:32 AM(UTC)
Kenmore washer leaking water on transmission (Washer Repair)
by arttruji 6/30/2016 11:55:27 AM(UTC)
Frigidaire Leaking water to floor (help!!) (Refrigerator & Freezer Repair)
by JB235161 11/13/2015 12:16:25 PM(UTC)
Maytag Leaking water NOT clogged (Refrigerator & Freezer Repair)
by radcliff299 7/26/2015 4:11:39 PM(UTC)
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 5/19/2015 10:50:03 AM(UTC)
Amana Leaking Water (Refrigerator & Freezer Repair)
by caelis 5/6/2015 7:29:02 PM(UTC)
Whirpool fridge leaking water inside (Refrigerator & Freezer Repair)
by Jules28412 3/28/2015 6:52:47 AM(UTC)
Whirlpool thin twin leaking water (Washer Repair)
by Propjake 2/20/2015 11:38:34 PM(UTC)
Kenmore Elite Leaking Water at Bottom (Dishwasher Repair)
by jsciarrino 2/14/2015 1:20:50 PM(UTC)
washer leaking water when washing front door (Washer Repair)
by OMAR MARTINEZ 8/13/2014 1:16:58 PM(UTC)
