dzieour@ranchomurieta.org
#1 Posted : Monday, November 24, 2008 10:21:59 AM(UTC)
Dryer works but Timer will not advance.
My original problem was dryer would shut down in mid-cycle and not start in either moisture control and timed cycle. I changed the timer and now the dyer works but will not advance in either timed or moisture control cycle.
Thanks! Dave
#2 Posted : Tuesday, November 25, 2008 10:48:27 AM(UTC)
Hi Dave,
The problem could be a bad timer motor, a bad moister sensor or a bad control board. Perform the troubleshooting as described in the Service manual (page 3-16).
Here are the break down diagrams for the Maytag Neptune stacked laundry unit Model MLE2000AYW.
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
Timer will not advance (Dryer Repair)
by Mechris 10/25/2016 6:30:42 AM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
by stevechar 9/21/2014 8:33:08 AM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Timer will not advance after lightning strike (Dryer Repair)
by jwahl16 9/3/2014 2:23:07 PM(UTC)
New timer will not advance (Washer Repair)
by meganbella 4/5/2013 7:02:18 AM(UTC)
GE washer timer will not advance. (Washer Repair)
by Chumlord 6/29/2010 2:52:09 PM(UTC)
Dryer timer will not advance (Dryer Repair)
by Brian7780 6/19/2010 7:23:44 AM(UTC)
Timer will not advance in cool down part of cycle (Dryer Repair)
by Blake1111 3/30/2010 2:00:14 PM(UTC)
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 (Washer Repair)
by ambsdr4god 11/8/2009 4:12:08 PM(UTC)
Timer will not advance in Auto Dry (Dryer Repair)
by KSherer 6/2/2009 6:17:52 PM(UTC)
Maytag timer will not advance (Washer Repair)
by Robinscs 2/18/2009 2:40:20 PM(UTC)
Dryer Timer Will Not Advance (Dryer Repair)
by cyclone 1/15/2009 9:42:24 AM(UTC)
