kchesley
#1 Posted : Saturday, November 22, 2008 8:32:59 AM(UTC)
kchesley
My frige/freezer quit cooling so I took off the back panel in freezer and noticed ice build up on coils but evap motor fan is not running. I unplugged the unit and cleaned off all the dust around condesor and all under back of fridge. I also replaced the evap fan motor but to no avail. Any tips on what to check now? Fan in back of fridge is running and compressor is warm. Thanks in advance
libertyappl
#2 Posted : Saturday, November 22, 2008 9:01:48 AM(UTC)
libertyappl
It sounds like a defrost problem. If you have an ohm meter check the defrost thermostat for continuity, it's located in the rear of the freezer near the evporator coils. In the back near the compressor the defrost timer is located there, try to manually advance the timer to kick te unit into defrost (try that first)
Here's your breakdown
Model SCD22TBW
Nat
kchesley
#3 Posted : Saturday, November 22, 2008 9:29:47 AM(UTC)
kchesley
I don't have an ohm meter. I can't seem to locate where the defrost timer is. Is it mounted onto the compressor because that is the only thing I see back there other than the icemake water hookup and the fan and the compressor. Thanks for the response. I'll keep trying to find it.
kchesley
#4 Posted : Saturday, November 22, 2008 9:52:04 AM(UTC)
kchesley
Ok, found defrost timer under front of refrigerator. Advanced until it clicked and the fan in back went off. Now what would be the next step? Do I have to wait awhile before doing anything else? Thanks in advance.
libertyappl
#5 Posted : Saturday, November 22, 2008 9:52:47 AM(UTC)
libertyappl
It is number 1541 on the machine compartment page.
Nat
kchesley
#6 Posted : Saturday, November 22, 2008 10:03:29 AM(UTC)
kchesley
Problem solved. It was the defrost thermostat as it was expanded/exploded. Replaced and everything is working just fine thus far. Thank you for your response and the info liberty.
libertyappl
#7 Posted : Saturday, November 22, 2008 11:01:00 AM(UTC)
libertyappl
Glad to help.
Kep us posted.
Nat
Amana side by side freezer - freezing intermittently (Refrigerator & Freezer Repair)
by handyandy71 1/6/2017 1:47:27 PM(UTC)
Older Amana side by side replacement thermostat (Refrigerator & Freezer Repair)
by smartyrodriguez 11/15/2016 7:26:55 AM(UTC)
Amana Side by Side not cooling (Refrigerator & Freezer Repair)
by craig72 10/18/2016 3:52:51 PM(UTC)
Amana side by side not cooling but compressor running (Refrigerator & Freezer Repair)
by steelers1 10/7/2014 7:33:52 PM(UTC)
Amana Side by Side Ice Buildup and Leaking (Refrigerator & Freezer Repair)
by LavaPit 8/25/2014 10:13:44 AM(UTC)
amana side by side not defosting (Refrigerator & Freezer Repair)
by jojowil 7/20/2014 5:45:20 AM(UTC)
amana side by side 20 degree freezer temps (Refrigerator & Freezer Repair)
by jdh022764 7/14/2014 7:55:37 PM(UTC)
Amana side by side not freezing (Refrigerator & Freezer Repair)
by mjp0074 8/27/2013 12:25:14 PM(UTC)
Amana side by side freezer not staying frozen (Refrigerator & Freezer Repair)
by hollykasper 8/3/2013 10:24:39 AM(UTC)
Amana side by side isnt cooling well (Refrigerator & Freezer Repair)
by kcruze 6/17/2013 6:27:21 PM(UTC)
Amana Side by Side Ref. (Refrigerator & Freezer Repair)
by sandraandlarry 2/25/2013 1:03:08 PM(UTC)
amana side by side refrigerator water line inside freezer door leaking (Refrigerator & Freezer Repair)
by borth 10/21/2012 9:01:56 AM(UTC)
Amana Side by Side (Refrigerator & Freezer Repair)
by hockey4179 7/29/2012 1:07:35 PM(UTC)
Amana side by side refrigerator side is freezing (Refrigerator & Freezer Repair)
by bsgcjg 10/15/2011 2:16:52 PM(UTC)
Amana side by side stopped cooling properly lastnight (Refrigerator & Freezer Repair)
by dgetty 8/4/2011 4:03:52 PM(UTC)
